Adding lights to the SRC Capri
Postby MrAdept » Tue Apr 02, 2013 12:10 am
I thought I would add some lights to the SRC Capri.
Headlights (4 white LEDs)
Tail lights (2 Red LEDs)
The nailfile under the back allows me to keep the car stationary.
Looks nice running around the track.
Mark
MrAdept
Re: Adding lights to the SRC Capri
Postby SOBwanhoser » Tue Apr 02, 2013 8:38 am
Very nice!
Curious though - did you use a ready made kit or DIY?
SOBwanhoser
Postby HomeRacingWorld » Tue Apr 02, 2013 9:00 am
Yes, nice job.
Postby Dangermouse » Tue Apr 02, 2013 9:47 am
Nice work, I have the LEDs I have the leads now all I need is making your own light kits 101
Dangermouse
Postby MrAdept » Tue Apr 02, 2013 10:40 am
It's DIY - I bought 50 white and 50 red LEDs and some 680 ohm resistors.
I have more pictures of a Cheetah and the wiring of it that I can post later.
Mark
MrAdept
Postby goosenapper » Tue Apr 02, 2013 3:29 pm
I'd also be interested in seeing how you wired the lights. I've stayed away from lighting some cars because, like this Capri, they had four lamps in front but most ready-made slot car lighting kits only have two headlights. Your DIY approach sure beats having to sacrifice the rear lights for four fronts.
goosenapper
Postby Dangermouse » Tue Apr 02, 2013 5:49 pm
Thank Jeremy - I need to get some diodes - I have visions of putting a Cap in the circuit (someone even sent me a circuit with working brake lights) but I can't read electrical diagrams - :lol:
I will check out you DIY post Mark
might be easy to make a circuit that doesn't have the lights stay on
DM
Dangermouse
Postby ListerStormGT » Wed Apr 03, 2013 8:31 am
That came out great, looks good with the lights!
