Home Racing World • View topic - VINTAGE MODIFIED CONVERSION
HO Scale Slot Car Forum
Postby Austin » Sat Mar 16, 2019 5:09 pm
Got one 1993 ERTL Jerry Cook Nutmeg Modified Legends Limited Edition
Got two HO SCALE VINTAGE MODIFIED CONVERSION kits
Kit includes:
(1) Front axle chassis extender
(1) Front axle 1/16"
(1) Front axle spacer tube (stainless steel - cut to fit)
(2) Body mounting posts with brass threaded inserts
(1) Rear mounting bracket - short (should fit most all)
(2) Rear mounting brackets - long (for large wheelbase cars)
(4) Secial wafer-head laptop machine screws for mounting posts
(1) Set instructions
Now to get a 4-gear chassis
Austin
Re: VINTAGE MODIFIED CONVERSION
Postby eastside johnny » Sat Mar 16, 2019 7:09 pm
Where/who did you get these?
eastside johnny
Postby RichD » Sat Mar 16, 2019 8:10 pm
Try NYModifieds dot com !
This car would have looked stubby if I used the regular long wheelbase, so I drilled new holes in the chassis. If you wanted to use a diecast body that still would not get you a long enough wheelbase, so the kit is the thing to use.
Postby sweet » Sun Mar 17, 2019 8:40 am
sweet
Return to HRW HO Scale
