Home Racing World • View topic - Scaleauto home set cars
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby sportblazer350 » Fri Mar 01, 2019 7:47 pm
i see that Scaleauto sells home set 1/24 scale cars now with a plastic chassis and plastic wheels. anyone try one yet? I have a Carrera track and the standard issue cars work great with aftermarket rear tires, but if I can buy the new home set cars for only $80 and get similar performance on my home track than I will go that route.
sportblazer350
Re: Scaleauto home set cars
Postby WB2 » Fri Mar 01, 2019 9:57 pm
If you look in the Cloverleaf Racing Forum you’ll see they are racing these cars. Drop a PM to Wicked Mini for info on the cars.
WB2
Postby dw5555 » Sat Mar 02, 2019 9:33 am
Actually I'm surprised that Mike hasn't chimed in or anyone else for that matter. These apparently aren't getting much ink as there is little wrote about them.
Dave
dw5555
Postby WB2 » Sat Mar 02, 2019 2:36 pm
I’d like to buy a running chassis for model conversion but all I see are complete cars and bare chassis.
WB2
Postby ALS » Sat Mar 02, 2019 3:03 pm
Hey the New R Series Flex Chassie Corrvett Cr7R Good runner. Adrian ALS Adrian
ALS
Postby sportblazer350 » Tue Mar 12, 2019 3:21 pm
what is an R series flex chassis car? never heard of it?
sportblazer350
Postby Cincyslots » Tue Mar 12, 2019 4:42 pm
Dang, $80 for a Scaleauto, I’ll be following this for sure. You’d think you’d have heard all about this.
Cincyslots
Postby cj74 » Tue Mar 12, 2019 7:11 pm
Good cars in general. The motor mount is fixed relative to the axle so changing gear ratio will be a challenge. If you want to run stock with just a change of rear tires they are a lot of fun to drive. I don't know which models come with which motor, but I've heard from many that there are two different motors that could be under the hood.
cj74
Postby dw5555 » Wed Mar 13, 2019 9:02 am
How bout someone doing a REVIEW????? They have been out awhile so I know it would be appreciated. Harry you got connections have them send you one. Anyone!!!
Dave
dw5555
Postby 32lbking » Wed Mar 13, 2019 9:48 am
32lbking
Postby noddaz » Wed Mar 13, 2019 11:02 am
My question is:
Are these capable of accepting Carrera or Scaley digital chips?
Scott
noddaz
Postby MrAdept » Wed Mar 13, 2019 12:06 pm
According to Pendleslot yes for Scalextric, Oxygen and Carrera.
Mark
MrAdept
Postby sportblazer350 » Thu Mar 14, 2019 10:09 am
my metal chassis Scaleauto cars with slip on urethanes on the rear wheels are fantastic on my Carrera track compared to BRM. For $80 it seems like a bargain if you want plastic gears, chassis, wheels. And then you have to start upgrades. For $160 I just need slip on rear tires for the home track and foam rears for the commercial track. Maybe i'll try one and see.
sportblazer350
Postby SuperSlab » Thu Mar 14, 2019 10:30 am
SuperSlab
Postby SuperSlab » Thu Mar 14, 2019 10:34 am
SuperSlab
Return to HRW 1/24 Scale
