Home Racing World • View topic - T/A 70 AAR Cuda
T/A 70 AAR Cuda
Let's build the big ones!
T/A 70 AAR Cuda
Postby Fitzy » Sun Sep 16, 2018 9:22 pm
Finally had a little time today to get the chassis fitted pretty happy with the way it fit together just want to get the nose a little lower then the interior tub and body can go to the body shop hope to have it in paint next week when the decals arrive.
Fitzy
Re: T/A 70 AAR Cuda
Postby arroldn » Sun Sep 16, 2018 9:52 pm
My TA Cuda should be here sometime this week. I had to order a resin hood because the kit had been opened and had a messed up hood. Not sure if I'll decal it as a 48 since you have picked the 42. Who are you getting decals from?
I see Mike's Decals has them.
arroldn
Re: T/A 70 AAR Cuda
Postby Fitzy » Mon Sep 17, 2018 5:13 am
Fitzy
Re: T/A 70 AAR Cuda
Postby btaylor » Mon Sep 17, 2018 5:28 am
Man that looks great already! On my Cuda, I left the front end where it was, and added small shims to the rear body mount area. that gave me some tire clearance, as well as that cool stance. I did use a different kit though, so it might not be an option.
Re: T/A 70 AAR Cuda
Postby HomeRacingWorld » Mon Sep 17, 2018 5:44 am
I know you will build a beauty of a car. Sure is cool seeing all this modeling going on and in both scales.
Re: T/A 70 AAR Cuda
Postby Fitzy » Mon Sep 17, 2018 7:34 am
Fitzy
Re: T/A 70 AAR Cuda
Postby btaylor » Mon Sep 17, 2018 7:55 am
Fitzy, My tires are larger in height and width. they measure 29 x 12.5 mm before truing. You can take them down a couple of mm on the tire truer if need be. I am sending out two different tire choices in the kit, one is treaded, the other is the Trifecta slick. either will work on your car im sure, as I have put them under all of mine.
I am currently trying to get all the first batch of tires cast and shipped out. I can send you another set shortly though. I'm trying to get everyone who asked a set first so they can start/keep building. More will available in the next few days. I am casting tires three times a day right now!
Re: T/A 70 AAR Cuda
Postby arroldn » Mon Sep 17, 2018 8:05 am
Fitzy I looked on the Pattos site last night. Wasn't aware he had TA decals. I must go look again. Considering a fantasy livery. With the number 53 or 79. This numbers are my birth year and birthday. OK found them under Plymouth.
arroldn
Re: T/A 70 AAR Cuda
Postby Fitzy » Mon Sep 17, 2018 8:46 am
Fitzy
Re: T/A 70 AAR Cuda
Postby Broman62 » Mon Sep 17, 2018 12:00 pm
Looking good so far...looking forward to seeing this finished!!
Re: T/A 70 AAR Cuda
Postby dge467 » Mon Sep 17, 2018 4:29 pm
Looking great!
Re: T/A 70 AAR Cuda
Postby TuscoTodd » Mon Sep 17, 2018 5:03 pm
That is looking good sir!
:banana-dance:
Re: T/A 70 AAR Cuda
Postby Fitzy » Mon Sep 17, 2018 8:58 pm
Fitzy
Re: T/A 70 AAR Cuda
Postby Fitzy » Tue Sep 25, 2018 9:18 pm
Made a little more progress I'm ready to finish sand clean up all the edges get all the panels aligned Interior is ready for paint I hope to be putting some color on this weekend.
Fitzy
Re: T/A 70 AAR Cuda
Postby btaylor » Wed Sep 26, 2018 3:39 am
Sure looking good fitzy! Tires and figure on the way.
Return to Taylor 1/24 TA Proxy 2018
Users browsing this forum: No registered users and 43 guests
