Home Racing World • View topic - New parts for scratch builders
Postby gascarnut » Tue Feb 27, 2018 10:56 am
I hope this is the right place to post this news. If not, I'm sure Harry will move it to a more suitable location.
I have had some custom brass guide tubes made and these will be available through Slot Car Corner, or direct from me within a week.
Most of you I'm sure have had issues with guide posts not fitting properly in regular K&S tubing sizes, and I know some folk have had issues adapting the regular 1/32 scale small guide posts into spring steel chassis that are designed to accept a guide with a 3/16" post. Well, your troubles are over.
These guide tubes are available in two designs, one with a flat surface at the bottom and one with a 3/16" spigot below the shoulder. The spigot allows for mounting in a steel chassis guide tongue or in any brass piece with a 3/16" hole:
The flat version can be installed from the underside of a tongue, or just soldered onto a flat brass strip:
The inner hole for the guide post is available in three sizes:
* 1/8" - to fit TSRF guides and many vintage guides that had 1/8" shafts
* 3.55 mm - to fit NSR and Slot.it guides, as well as the ScaleAuto SC16007 and 1608 replacement guides and any others with a similar size
* 3.7 mm - to fit the Scale Auto SC1603 and 1604 guides, the Sloting Plus guide, and any others with a similar size
The tube length is generous enough to accommodate all guide post lengths, and can obviously be cut to size as required,
MSRP is $2.95 each, and as I said, these will be in stock at Slot Car Corner early next week.
The prototypes for these have been tested by some notable builders, and I hope they will chime in here with their experiences.
gascarnut
Re: New parts for scratch builders
Postby RBPhillips » Tue Feb 27, 2018 12:52 pm
I was staring at this problem yet again last night - thanks, I'll be buying some next week!
RBPhillips
Postby nhdungeonracer » Tue Feb 27, 2018 2:54 pm
Great idea Dennis!!! :auto-checkeredflag: :auto-checkeredflag: :auto-checkeredflag:
Postby HomeRacingWorld » Tue Feb 27, 2018 8:11 pm
OH now we are cooking with Crisco!
Great idea and a very big THANK YOU!
Postby SlotCarCorner » Wed Feb 28, 2018 7:26 am
First, kudos to Dennis for bringing these well thought out parts to market for the scratch building community. We'll follow-up with a post once we actually have them in hand.
:text-thankyouyellow:
SlotCarCorner
Postby chrisguyw » Wed Feb 28, 2018 8:36 am
chrisguyw
Postby SlotCarCorner » Mon Mar 05, 2018 6:15 pm
SlotCarCorner
Postby Broman62 » Mon Mar 05, 2018 9:32 pm
Another great innovative design for our slot car world... :text-bravo:
Postby TuscoTodd » Mon Mar 05, 2018 10:16 pm
Excellent! :D
Postby munter » Tue Mar 06, 2018 2:18 am
If I bought the 1/8" id piece is there enough meat to open it up for larger diameter guide posts?
munter
Postby SlotCarCorner » Tue Mar 06, 2018 5:29 am
SlotCarCorner
Postby gascarnut » Tue Mar 06, 2018 10:16 am
gascarnut
Postby gascarnut » Tue Mar 06, 2018 10:34 am
While I'm here, just a few more little tips:
1. The internal diameter has been drilled accurately and is obviously the same diameter all the way along the length of the tube. The guide posts, however, usually have a slight draft angle on them so they are bigger at the bottom of the shaft than at the top. You can adjust this misfit in two ways. One is to use some fine sandpaper to sand down the guide shaft; the easier way is to open up the bottom of the guide tube hole a little. This can be done with a taper reamer, or with a sharp X-Acto blade, or even a small round file. A taper reamer is a useful thing to have anyway, here's one version:
https://www.micromark.com/T-Handle-Reamer
In particular when using the Slot.it wood guides, this is needed. I would suggest starting with the 3.7mm tubes for that guide.
2. Since all the tubes look the same apart from the internal diameter, they are marked to identify them. The 3.7mm tubes have two small drill dimples at the top of the outer diameter, the 3.55mm versions have one dimple, and the 1/8" versions are plain with no dimples.
3. Not all guides have a tall enough post to reach the top of the tube, but it is easy enough to trim the post down with a file or a cutting disk in a Dremel tool, or even a small metal saw. I usually leave them as long as the body clearance will allow, to give as much support as possible.
gascarnut
Postby munter » Wed Mar 07, 2018 12:26 pm
munter
Postby Audi1 » Sat Mar 10, 2018 6:59 am
Nice products! Will definitely be giving them a try. Noted that the 3.7 version is now out of stock at SCC.
