Fast forward to today, an unbelievably frigid cold day, everything you touch, your finger sticks, no way I'm going outside. I get that old unfinished car out and begin work. Have you ever stripped the clearcoat off one of those things? Wow, that stuff is nasty. I never did get it all. I sanded it and shot some primer, which held nicely. If it hadn't held, I don't know what I would have done. I emptied my bag of tricks in the first hour. It felt like some kind of vinyl, and it only softened a little in alcohol. I whisked it with lacquer thinner and was afraid I might soften the plastic to much, and I tried acetone and several other things. In the end I gave up and went after it with #600 wet paper. I've never seen a finish that sticky, stubborn, or thick on anything.
The blue car with the red stripe is what I'm planning on.
