Thunder Slot Lola Part 2
Share Your Thoughts!
Postby HomeRacingWorld » Sun Aug 28, 2016 10:19 am
When these were released I decided I wanted both of them. I am one of those that like to have a matched running mate for the closest door to door action I can get.
My car arrived from Power Hobby safe and sound and time to have some fun.
Finish on this model is like the first. Very clean and good clear coat for shine.
Another reason I like having a matched pair is experimenting. I can try different tuning techniques and testing them side by side adds to the fun.
So I decided to make my own independent fronts using the common axle collars you can find at SCC, Cloverleaf, etc.
In stock form the collars are just slightly too wide to fit in the narrow space of the chassis. So I mounted the collar on the axle with the axle just counter-sunk enough to allow the set screw to make a secure hold. Then I filed the collar with a large flat file to flush.
Just enough for the collar to stay intact and provide a good fit.
Perfect. No contact and read y to race.
On my track there isn't much difference if any. It's still silky smooth and fun to race, so no harm done either.
SANDING - I have to say that sanding the rear tires smooth is the hot setup for my track. The flash molding on the rears can cause a bad hop. Once sanded however, these cars are both scale rockets and provide the fun I was hoping for.
With my son around now, it's a hoot to watch him take to wood track racing. He doesn't care much about the scale issues, he just thinks they "look cool and are smooth". I suppose in that view these releases score a win :)
Thanks again to Power Hobby for great service.
Re: Thunder Slot Lola Part 2
Postby SlotCarCorner » Sun Aug 28, 2016 2:02 pm
Great tip on the independent front axle/wheel setup.
:text-thankyouyellow:
SlotCarCorner
Postby HomeRacingWorld » Sun Aug 28, 2016 11:06 pm
Thanks guys.
Yes, I think so but I'm odd that way.
I spent some extra time today just running them. Just fun to try and best the lap time of the previous run :)
Postby Brumos RSR » Mon Aug 29, 2016 9:34 am
Great part 2!!! Did you find any improvements with the independent front over the conventional front end set up?
Brumos RSR
Postby HomeRacingWorld » Mon Aug 29, 2016 10:19 am
Thank you sir.
No difference here, but we have a modest size layout. So hard to say either way.
Return to Product Reviews!
