Home Racing World • View topic - I need 2 yards of cooper tape
Got Wood?
Your ROUTED TRACK Home!
Postby Cincyslots » Mon Feb 08, 2016 7:35 am
I've used cooper tape from Hobby Lobby for a routed track and it worked pretty well. I'm using the same tape on another project but it's not making a good connection. Does anyone have a better tape that they would like to sell me about 2 yds?
Thanks,
Bruce
Cincyslots
Re: I need 2 yards of cooper tape
Postby Cincyslots » Mon Feb 08, 2016 9:24 am
Thank you!! Any luck on the axles carriers?
Bruce
Cincyslots
Postby dw5555 » Mon Feb 08, 2016 4:57 pm
Bruce + axle carriers = Carrera + 1/24 scale = something I might want.. :D
Dave
dw5555
Postby frank9129 » Mon Feb 08, 2016 7:45 pm
Bruce,
It's not often that I can help someone with equipment.
I have a roll of 1/4" copper tape with conductive backing. I did my entire track with it.
When ever there is a problem I just snip enough to cover the break and away I go.
Kids can be rough on a track. I keep a roll on hand.
www. tapesmaster.com
1/4" x55yds copper foil tape (6mmx50mm)
$11.25 per roll (in 2014)
If you would like 6', let me know.
You have been there for me, even when I am on vacation.
Frank
frank9129
Postby Cincyslots » Mon Feb 08, 2016 7:54 pm
Thanks Frank. I normally do the same but for this application, that's not working. Let's see what bibs has. Thanks again.
Bruce
Cincyslots
Postby waaytoomuchintothis » Mon Feb 08, 2016 7:55 pm
I think a lot of folks overpay for copper tape. I usually pay $6-$8 a roll for the thicker, high quality 1/4" stuff from Venture, and less when I get quantity. I use it for stained glass that I do for door inserts on custom furniture I design and build.
Postby Giddyup » Mon Feb 08, 2016 9:08 pm
Giddyup
Postby buspor63 » Thu Feb 11, 2016 10:29 pm
buspor63
Return to The Lumber Yard
