Home Racing World • View topic - Monogram Ferrari Rebuild
Re: Monogram Ferrari Rebuild
Postby goosenapper » Mon Jan 26, 2015 11:41 am
Thanks for that info. Those tires do look great on there.
goosenapper
Postby btaylor » Mon Jan 26, 2015 11:55 am
Thanks Harry! I didnt know what PG tire fit those. I need to get a few sets of them.
Postby HomeRacingWorld » Mon Jan 26, 2015 12:14 pm
Hey, you are welcome. It is a great tire to hang on the wall as it fits 14 and 15 size wheels.
Anyway, here is a start on the front axle.
This should give you a good start point.
Postby HomeRacingWorld » Wed Jan 28, 2015 9:59 pm
Postby scatman » Wed Jan 28, 2015 10:26 pm
Bad to the bone. I salute you Sir.
scatman
Postby dreinecke » Wed Jan 28, 2015 10:38 pm
Looks clean and neat. How's the noisy body with the new chassis?
Postby HomeRacingWorld » Wed Jan 28, 2015 10:41 pm
Not that noisy :)
Want a chassis?
Thanks guys. Appreciate the comments.
Postby HomeRacingWorld » Wed Jan 28, 2015 10:46 pm
Don't worry, now it's JALOPY TIME :)
Will be quite busy with the small fleet of them. I cannot wait to get started.
Next classic will be the 250. But that will have to wait.
Postby btaylor » Thu Jan 29, 2015 5:59 am
That sure is one great looking car! I dont have that one in my collection (yet) but would sure like to add one.
I have a 250, and it needs a chassis like that one. Nice build Harry, and thanks for the tire tip, i have some on the way.
Postby Audi1 » Thu Jan 29, 2015 7:56 am
That came out really well! And, as someone posted earlier, the wheels and tires look great. I like the lightweight chassis, too; probably runs pretty quick now.
I've used Meguiars on boats, but never on plastic cars. Looks like a nice shine there. I wonder how it would fare with waterslide decals(?)
........and, it would fit right into the ROAR fun run that we're starting up now! What do you say?
Postby goosenapper » Thu Jan 29, 2015 8:07 am
Is there no need for the motor shaft to hold the gear in place when using those 1.5mm shaft Slot/it pinions? I had thought that you'd still have to sleeve the shaft beyond the pinion in order to keep the axle from moving around and fudging the mesh.
The car turned out great. I can't believe what a difference to the appearance a good shine can make. That's a pretty simple body by 1/32 standards, yet it looks on-par with the shiny wheels after you've polished it up.
Great chassis too. Who needs bushings, right? Seeing a simple yet effective chassis like this makes me want to try building one.
goosenapper
Postby HomeRacingWorld » Thu Jan 29, 2015 9:40 am
I did not sleeve the shaft as it's not centering the system. I cut the rear axle tubes to set the correct width.
Been using the wax with all of my builds lately. Really adds a deep shine and does not harm decals.
Thanks all for the comments.
Postby HRWJim » Thu Jan 29, 2015 10:45 am
That thing looks great Harry. Those wheels really set it off. Jim
Postby Audi1 » Fri Jan 30, 2015 5:54 am
Postby HomeRacingWorld » Fri Jan 30, 2015 6:47 am
No sir. It will only give you a nice shine and help in resisting finger prints and normal handling. Not a substitute for a clear sealing.
Future is your Future. Well, Pledge FloorCare. I use nothing else. 2 coats and then a couple coats of this polish.
Unless you are using the lowest grade decals made that have not been sealed to the paper, this is your clear coat solution that is safe for your decals.
Thanks Jim. Will use same design on the 250. Not sure how it would work on the Cooper. It's a very low profile model.
Return to The Slot Car Garage
