My first semi-scratch build
Postby KD11 » Mon Jan 26, 2015 12:45 pm
I have attempted my first scratch build chassis. I am running a Carrera digital 132 Oval, so I knew I would be adding the Carrera digital module. I had purchased a 1940 ford coupe AMT model for the body and had purchased a H & R chassis. I could of used the chassis as is but decided to follow Harry's instructions the best I could to build the front rails. My first attempt was ok but I didn't bend the chassis rails straight, slightly bent off to the right. I decided to solder them in anyway and boy was my soldering ugly!! I soldered on the front axle tube and guide mount. Now I had to figure out how to mount the digital module as it is to wide to set in between the rails. I used some double sided tape to hold the module in place so I could test to make sure it worked and the car would activate the lane changers. I temporarily mounted the body and tested the car. All seemed to work ok but I needed to redo the chassis rails and clean up the ugly soldering job. With the chassis rails fixed and chassis cleaned up I then added a piece of brass to permanently mount the digital module. I used the original car interior and mounted the body using brass tabs that I tapped and screwed onto the chassis. Then I glued the body to the body mount tabs. Tested the car again and it seemed to run ok but the H & R tires did not have any grip so I purchased a pair of Pro-Track silicone tires from our local shop. These are better but I will purchase a pair of PGT tires in the near future. Next was to paint the body, this turned out to be real pain. I thought I would learn how to use an airbrush and use Acrylic paint. As it turned out it is easier said that done. I have lots to learn about using an airbrush as the paint still isn't dry. I guess on put the paint on too thick or didn't let the previous coats dry. Anyway I decided to add the LED headlights and tail lights. All in all I think it turned out ok and I have begun the learning process of finding out what works and what doesn't. Thanks to all of you that provide such great information for us newbies.
Keith
KD11
Re: My first semi-scratch build
Postby HomeRacingWorld » Mon Jan 26, 2015 1:30 pm
Outstanding. That's the way, just give it a go and look what happens:)
Postby btaylor » Mon Jan 26, 2015 1:30 pm
Certainly doesnt look anything like a first build chassis! I wish mine looked that good!
nice work, and the body choice compliments it.
Postby TsgtRet » Mon Jan 26, 2015 2:00 pm
Outstanding work! I won't even attempt a brass chassis until I get a decent soldering iron/gun. The light kit sets it off nicely.
Postby woodman » Mon Jan 26, 2015 5:43 pm
Keith that turned out great. ...l need to get back on my 49 Ford.......
woodman
Postby KD11 » Tue Jan 27, 2015 10:43 am
Thanks for all of the kind comments. I would like to build some jalopies in either 1/32 or 1/24 scale. I know some of you guys are making your own resin bodies for your builds. Do any of you sell the bodies you make? If so let me know I would like to purchase several.
Keith
KD11
Postby RazorJon » Tue Jan 27, 2015 11:44 am
stop the presses :text-bravo:
first time out of the gate and head lights too :bow-blue:
very well done, I am sure a few of our casters would love to help out your needs
Postby MrAdept » Tue Jan 27, 2015 2:31 pm
The chassis looks awesome especially as it has the Carrera digital board attached.
Mark
MrAdept
Postby buspor63 » Tue Jan 27, 2015 3:16 pm
That's a great build from start to finish. Hmm, I like those bumpers, there's some times when those would be handy on my 917K
buspor63
Postby Czar » Fri Feb 06, 2015 1:59 pm
Better than good - it is inspiring!
Czar
Postby bobbyraz49 » Fri Feb 06, 2015 2:47 pm
Stunning !
bobbyraz49
Postby TuscoTodd » Sat Feb 07, 2015 11:28 am
WOW!!!
That is an IMPRESSIVE first build!
Kudos!!!
Postby ddyke » Sat Feb 07, 2015 12:13 pm
Nothing semi about that!
ddyke
Postby proxieken » Sat Feb 07, 2015 1:47 pm
Very nice job. I was wondering if anyone puts digital in the older style chassis, and the answer is apparently yes. This gives me some inspiration for sure.
proxieken
