Home Racing World • View topic - A little sparse, but it’s a tree~
Plastic Or Wood
All Things Track Building!
Postby turbokev » Sat Nov 08, 2014 8:07 pm
Decided it’s time to add a few trees to my track.. and not those tiny ‘trees’ that are about
seven feet tall in 1/32 scale.. A normal sized tree about 35’ is what I was thinking..
First I went outside and found some suitable sticks to make a tree out of..
Then I trimmed some and started adding branches to the main ‘trunk’.. I used a dremel bit about the same
size as the branch I was adding and made the hole deeper than you see here so the new branch would slide
in and fit well.. I used (get this) wood glue to hold them together..
Next I added some fall foliage from Woodland Scenics.. none of it is glued, it’s just draped around.
Looks just OK.. hard to get a fully covered tree look so I’m just going with the story that it represents
the track in the fall, and many of the leaves have already fallen 
The tree is mounted to a nail sticking up through the track..I drilled a nail sized hole in the base of the tree.
After I took some of these pictures I sprinkled a few fallen leaves down under the tree.. I think it looks
pretty good scale wise.. not towering, and not like a bush..
turbokev
Re: A little sparse, but it’s a tree~
Postby Xr4ti » Sat Nov 08, 2014 9:11 pm
:lol: What planet is that tree from? :lol:
Looks like fall colors :clap: beauty!
Xr4ti
Xr4ti
Postby HomeRacingWorld » Sat Nov 08, 2014 10:22 pm
I like the style, just go outside and get one :)
Postby TsgtRet » Sun Nov 09, 2014 12:52 am
Postby TuscoTodd » Sun Nov 09, 2014 2:57 am
I like it! And the tree swing is a cool addition! :)
Postby btaylor » Sun Nov 09, 2014 6:36 am
That looks great Kev, The fall colors look good on any track to me.
Postby dreinecke » Sun Nov 09, 2014 12:27 pm
Looks great to me!
Postby Ember » Sun Nov 09, 2014 3:21 pm
Good beginnings. If I may make a little suggestion?
Use some polyester stuffing for cushions, etc to bulk up the canopy first. I like mine black because it disappears, but I think Woodland Scenics do green. Just needs an open light coverage, but it will give you a better coverage. Then you can sprinkle crumbed foam or 'leaves' for your foliage.
These are not great examples, but they're the only photos I have.
