AFX Wiring
AFX Wiring
Postby hillbilly » Sat Apr 13, 2013 7:35 pm
Getting ready to set up an AFX track can some explain to me how to wire it using a AFX plug in power supply one for each track. its going to be a two lane track. Thank Hillbilly
hillbilly
Re: AFX Wiring
Postby HomeRacingWorld » Sat Apr 13, 2013 7:41 pm
The diagram below illustrates how to wire any Tomy AFX 2-lane race track to use individually powered lanes. This method will effectively double the power available to each car, and eliminate the power surge problems associated with a single power supply.
Simply insert a second Tomy AFX power terminal track into the layout with the connection block exiting from the same side of the track as the first one. Then connect one power pack and one hand control to each power terminal track. Each hand control needs to be connected to the corresponding lane it will regulate.
The diagram above shows two power terminal tracks placed next to one another for simplicity, but they can actually be placed anywhere around the raceway to allow the two drivers stations to be located at different points around a larger table.
From Greg Braun
Re: AFX Wiring
Postby hillbilly » Mon Apr 15, 2013 5:29 am
Thanks Harry. I have trying to figure that out for a week. Hillbilly
hillbilly
