Home Racing World • View topic - The new JJ Slots 1:64th scale
Postby jwlslotcars » Tue Apr 30, 2019 4:30 pm
jwlslotcars
Re: The new JJ Slots 1:64th scale
Postby HO RacePro » Wed May 01, 2019 11:22 am
I'm very curious what you are using for pickups on your new chassis. Conventional hard HO pickups usually do not work well on the type of power conductors used for 1/43rd scale track.
Could you show us some closeups of the chassis? (I can understand if you don't want to.)
I'd also like to see the chassis running without the traction magnet. Since you are using a can motor, there should be little to no magnetic downforce without the traction magnet, so it would be an authentic gravity car. But the lack of downforce could cause an issue with the pickup system -- either result in poor power pickup and/or lift the front wheels off the track.
Ed Bianchi
HO RacePro
Postby jwlslotcars » Fri May 03, 2019 11:53 am
jwlslotcars
Postby dge467 » Fri May 03, 2019 4:30 pm
Pretty cool! Is there going to be a wide assortment of bodies?
Postby jwlslotcars » Sat May 04, 2019 7:47 am
jwlslotcars
Postby HO RacePro » Sun May 05, 2019 1:47 am
Why the oblong guide pin? It could bind in the slot if the car drifts.
Ed Bianchi
HO RacePro
Postby noddaz » Sat May 25, 2019 8:08 pm
noddaz
Postby jwlslotcars » Tue May 28, 2019 12:09 pm
Could be, These cars will rock a 1:43 track.
jwlslotcars
Users browsing this forum: No registered users and 40 guests
