Puling Wheels
Puling Wheels
Postby CharlieB72 » Sun Mar 17, 2019 9:47 pm
Other than the obvious, using a gear/wheel puller, what's the best way to pull re move the wheels on an AW and TJet chassis?
Thanks
CharlieB72
Re: Puling Wheels
Postby RichD » Mon Mar 18, 2019 7:26 am
You can pry off the wheels using a tool with a thin blade, like an X-Acto knife. It is better to use two such tools to avoid damaging the wheels. If you expect to work on your cars a lot you should spring for a proper wheel puller.
There is a list of tools included in this article: https://drive.google.com/file/d/1msYjFT ... sp=sharing
Re: Puling Wheels
Postby model murdering » Mon Mar 18, 2019 9:28 am
A tack puller ... an upholstery tool.
For stubborn ancient plastic hubs that are impossibly stuck, pre-soak in warm water.
model murdering
Re: Puling Wheels
Postby CharlieB72 » Mon Mar 18, 2019 11:25 am
Thanks for the replies. Really appreciate the help.
CharlieB72
Re: Puling Wheels
Postby Norman » Mon Mar 18, 2019 5:57 pm
I always used a small flat tip screw driver to pry off wheels before getting a wheel puller.
Norman
