Home Racing World • View topic - Hot wheel Porsche LH in resin
Postby Ky.Slot Racer » Sun Mar 17, 2019 11:35 am
made to mount to a AFX or AW mag trac chassis with 1 screw.
Ky.Slot Racer
HRW Master Modeler
Re: Hot wheel Porsche LH in resin
Postby sadco racing » Sun Mar 17, 2019 5:29 pm
Great job on this Mark, you got talent brother!
sadco racing
Postby ourwayband » Sun Mar 17, 2019 7:16 pm
Man she just looks fast!
Great job..
Postby noddaz » Mon Mar 18, 2019 5:53 pm
I have that diecast! What a great looking resin cast! Are you going to paint it in Gulf colors?
Scott
noddaz
Postby Norman » Mon Mar 18, 2019 6:00 pm
Nicely done, Mark!
Yes, Gulf colors would look perfect on that car!
Norman
Postby Ky.Slot Racer » Mon Mar 18, 2019 7:11 pm
Actually this is a dummy cast, so i can work on a few things, remove window areas. Ppen vents, add vents, then smooth the body a bit more and recast it. Then i can mold clear windows as i build.
Ky.Slot Racer
HRW Master Modeler
Postby Ky.Slot Racer » Thu Apr 11, 2019 12:42 pm
changed direction a bit on this, as going with the AFX 1.5 mega g plus chassis rather than the AW xtrac.
This is my test mule for the body mounting, trimming for tire clearances.
and the 1st 3 paint jobs: These all are from the second mold and casting, so the head light buckets have been filled with epoxy.
This is the 3rd casting, this time with the headlight buckets removed, and castings also made for clear glass/headlight lenses, and a motor detail part.
Ky.Slot Racer
HRW Master Modeler
Postby waaytoomuchintothis » Thu Apr 11, 2019 3:47 pm
NOW I understand the transition! You have conquered 1/24th and 1/32nd better than anyone, and now you are going to conquer HO! PLEEEEEZE don't go 1/43rd on us. The earth's axis could shift.
Postby ourwayband » Thu Apr 11, 2019 7:00 pm
Those look GREAT!!!
Postby padirtfan » Tue Apr 16, 2019 8:52 am
Mark, You never cease to amaze me! That is mighty fine work.
padirtfan
Postby Ky.Slot Racer » Tue Apr 16, 2019 11:04 am
finally getting the clear parts to a quality I am happy with.
Ky.Slot Racer
HRW Master Modeler
Postby MrAdept » Tue Apr 16, 2019 11:06 am
How do you get the clear parts so clear?
Like crystal!
Mark
MrAdept
Postby Ky.Slot Racer » Tue Apr 16, 2019 11:24 am
Ky.Slot Racer
HRW Master Modeler
Users browsing this forum: No registered users and 42 guests
