Tyco Pro track with broken tabs - Is there a fix?
Postby mike116 » Mon Feb 18, 2019 3:33 pm
I have an old Tyco Pro set. Some of the track pieces (specifically the curves) have one broken tab. The track pieces still seem to work (they have an electrical connection) but they're not smooth and the cars tend to hiccup right at those spots (or worse they de-slot). Is there any fix for this that anyone has used effectively?
Thanks.
Mike
mike116
Re: Tyco Pro track with broken tabs - Is there a fix?
Postby RichD » Mon Feb 18, 2019 4:59 pm
Aurora made steel clips to hold their track sections together, those might work with Tyco track. The clips are still available, but they can be rather expensive. JAG Hobbies sells two for $.75. NCP Hobbies has 24 for $6.98. They would be a good solution if you don't need a lot of them.
Postby mattb » Mon Feb 18, 2019 6:28 pm
There will be many places where you connect 2-3 curve tracks together for every type of layout you try, same with straight track. You may consider just gluing those broken sections together. You can lay them upside down, cut some kind of plastic strips to fit underneath, squirt a little superglue on, press the bridge strips to the bottom of the tracks, wait a minute or two and turn over a solid section of tracks with smooth joints.
Postby mike116 » Mon Feb 18, 2019 9:47 pm
Perfect. Thanks.
mike116
Postby TuscoTodd » Tue Feb 19, 2019 7:42 am
Mike - Tyco actually made their own repair clips as well - I am not sure of a current source for them - but the new TOMY ones look very similar - but the spread may be different?
Here are pictures of the Tyco clips:
And for comparison sake - here is a picture of the new TOMY clips - not sure how the gap between the arms compares, but the design looks very similar. They are available via multiple sources, at a reasonable price and may be worth picking up to try? (note they do press on HARD - but on the AFX track they make the joint nearly seamless!)
Postby mike116 » Tue Feb 19, 2019 3:14 pm
Great! Thanks.
mike116
Postby Tycosaur » Sat Mar 02, 2019 8:31 pm
The Aurora clips held the pieces tighter than the Tyco clips. You can cut the Aurora clips in half with a pair of tin snips to get two from one.
Tycosaur
Users browsing this forum: No registered users and 42 guests
