Home Racing World • View topic - clear window plastic removal
Postby Fast_Eddie » Sat Feb 09, 2019 8:46 am
Fast_Eddie
Re: clear window plastic removal
Postby dge467 » Sat Feb 09, 2019 11:18 am
I usually take my Dremel tool and carefully grind the 4 points they melted the glass to the body.
Postby BIG E » Fri Feb 15, 2019 1:19 pm
...and that's all ya need to do! Use a round ball grinder bit about 1/8" in diameter or so.
Here's a tip - run the rotary tool at the lowest speed possible. It's easier to control and there will be less chance for accidental slipping.
Go slow until you get the feel of the job, it's an easy task. You can trim away some of the excess clear plastic from the window insert before re-installing it.
A small dab of white craft glue on the underside of the roof will hold it in nicely, and any excess can be wiped away with a damp cloth.
STAY AWAY from using model cements or CA glues ("crazy glue" type products). You'll make a mess of your new paint job and windows with that stuff!
Hope this helps you out, and... Enjoy! -- Ernie :>)
BIG E
Postby Fast_Eddie » Fri Feb 15, 2019 4:14 pm
Got the 1st one done. It only had 1 spot where it was attached. But worked like a charm ! Thanks guys :text-thankyouyellow:
My rotatory tool is a cheapie drill master from harbor freight and only has 1 speed. I just got it but see it will need to be upgraded to a multi-speed
Painting at 1:64 scale is sure a lot harder than 1:24 ....WOW !!! :scared-eek:
Fast_Eddie
Users browsing this forum: No registered users and 41 guests
