T-Dash Generation 2 Testing
Postby RichD » Mon Aug 27, 2018 12:07 pm
I have been testing a T-Dash Generation 2 chassis, those have been difficult to come by because they are made in batches and tend to sell out quickly. You have to go to the website and see when the next batch will be available, if you order within a day of that time you might be in luck. The cars cost $13 plus shipping, there is a discount if you buy five.
For a start all of the Dash parts are interchangeable with the original Aurora Thunderjet parts. The car was supplied with the shoes and shoe springs in a separate bag as were the tires and guide pin. The complete rolling chassis with a guide pin weighs 16.5 grams. I checked the shoe spring pressure and that was about ideal at 3.0 grams. The shoes did not have to be adjusted to ride flat on my track rails. The car has very nice looking American Racing style chromed wheels, the front wheels are 0.253 inches in diameter and the rear wheels are 0.275 inches in diameter. The tires have very good grip, the fronts are 0.385 inches in diameter and the rears are 0.400 inches in diameter.
The front track is 1.025 inches and the rear track is 1.146 inches. The magnets read 746 gauss for the white magnet and 729 gauss for the blue magnet, Dash magnets that I measured several years ago were 850 gauss. The 16-3 armature measured 18.0 ohms on all three poles at 77°F (25°C). The motor brushes are flat on top and have notches on the bottom.
I glued the guide pin to the chassis and found a resin Plymouth Superbird body that was a perfect fit.
After I oiled the car I ran some laps on my MaxTrax 4X16 foot oval using the 35 foot red lane. The track voltage was set at 18.5. The fastest lap was 3.936 seconds, the gears were a little noisy but the car ran smoothly. The idler gear was a perfect fit on its post, the gears were not bottomed out, the axles were not loose in the axle holes, but the armature shaft hole and cluster gear shaft holes in the gear plate were a little loose.
As a comparison I ran four of my 1st generation T-Dash cars around the track. I use those cars for IROC style racing, they have Wizzard weighted front ends, CNC crown gears, drill blank axles, CNC wheels and Pro Series silicone Super Tires. All of the cars had their gears lapped and they had either a '70 Chevelle or Olds 442 body. Those cars are lower and wider than the test car, so they corner better. The best lap times were 3.375, 3.369, 3.148 and 3.215 seconds. The 1st generation cars had 14 ohm 3 lamination armatures.
I tightened up on the gear plate holes and lapped the gears for a total of 45 minutes. The gears resisted lapping and they still sounded a little rough, but the car was a bit faster down the straights. The lap time dropped to 3.661 seconds and I needed to use a fair amount of brake. The limiting factor was mostly the lower cornering speed compared to the IROC cars. Finally I switched to a pair of magnets that were matched at 862 gauss and that got the time down to 3.501 seconds, I still needed brakes. I may configure the car closer to Fray/T-Jet SS trim in the future.
These cars are a real bargain, they can be run right out of the box with little tweaking being necessary to get a decent runner.
Re: T-Dash Generation 2 Testing
Postby HomeRacingWorld » Mon Aug 27, 2018 1:39 pm
:banana-gotpics:
Interesting but... :D
Postby RichD » Tue Aug 28, 2018 9:42 am
Pictures! Here you go.
T-Dash Generation 2 rolling chassis.
T-Dash with Superbird body.
T-Dash Generation 1 IROC cars.
T-Dash Generation 1 IROC chassis.
Postby Ky.Slot Racer » Thu Aug 30, 2018 2:52 am
Good information Rich, thank you ! I missed out on the last batch, had to work that night and forgot all about it. Boy they went quick. I have yet to play with one, I got 10 from the previous batch and have a few parts on the way to get going on one or 2. I have had pretty good luck getting a few aurora t jets to really scoot around the track, amazing with the parts available how fast these dudes with no magnet help can be persuaded to go with a little patients and work.
Ky.Slot Racer
HRW Master Modeler
Postby RichD » Thu Aug 30, 2018 8:33 am
I ordered the car at the moment that they became available, a day later there were some left, but by the next day they were all gone. The next batch will be pink (!) and will go on sale on 9/9 at 6 PM central time.
I presume that you have seen my T-Jet tuning article. https://drive.google.com/file/d/1msYjFT ... sp=sharing
I did a separate article for the original T-Dash, https://drive.google.com/file/d/1hzUoot ... sp=sharing , but the new chassis lacks the quirks that the Generation 1 had, so the T-Jet article works for both.
I did not run any full blown T-Jet SS cars for comparison, mine all had guide pins that are too long for my track. I intend to do more testing when my track is back in its road course configuration. The lap record on that for a T-Jet SS car with a Fray style body is 5.4 seconds. With a Fray body the Generation 1 T-Dash IROC cars ran 5.6-5.7 second laps. The T-Jet SS car less the body has about $120 worth of parts. The IROC cars cost about $34.
