120 ohm controllers
120 ohm controllers
Postby Lone Beagle » Mon May 28, 2018 9:44 am
Hi, guy here. I just set up my AFX Endurance Champions set with the Tri-voltage power pack and 120 ohm controllers. One car seemed consistently a lot faster by switching lanes then controllers I narrowed it down to one of the controllers. Does anybody have any thoughts of how to correct this?
Lone Beagle
Re: 120 ohm controllers
Postby model murdering » Mon May 28, 2018 10:18 am
If you have a meter, or a buddy with a meter; pull the trigger closed and check the resistance. If its out of range simply call Racemasters. They have a legendary reputation for high quality customer service.
As a matter of course, I'd check both controllers for total resistance, AND the variable range between the stops.
model murdering
Postby Lone Beagle » Mon May 28, 2018 11:40 am
Thank you. That is it. One repeatedly went into the 110s and the other never went about 79 ohms
Lone Beagle
