HOCOC Spec Stock Class
Postby RichD » Fri Jul 14, 2017 7:56 am
For the upcoming season HOCOC will be running a Spec Stock class. This will be the first time that we will be running modern inline cars, except for G-Jet types, since 2011. I converted some Wizzard and BSRT SS cars to Spec Stocks and also built two new Viper cars from parts. I could have just bought some Viper cars, their Spec Stock version is reasonably priced, but I already had the chassis plus some other parts on hand and I needed to get used to working on them as well as the BSRTs once again. I needed to find the right combinations of slip-on tires and wheel diameters for each make, which by itself took some effort. I also had to get back into painting and mounting Lexan bodies, I had only done one of those in the last eight years.
Our rules and other info can be found here: http://hococ.weebly.com/
