G-Plus / Sizzlers motor swap?
Postby TeamMadMarsupial » Thu Dec 29, 2016 8:08 pm
Have any of you ever heard of swapping out a Sizzler motor into a G-Plus chassis. I hear from a long time racer that this produced one of the fastest slot cars he had seen .
TeamMadMarsupial
Re: G-Plus / Sizzlers motor swap?
Postby RichD » Fri Dec 30, 2016 8:05 am
I had never heard of a Sizzler before, so I had to do some research. Those were part of the Hotwheels line, the cars were battery powered and used an open can type motor. I would expect that the motor is intended to be run at a low voltage, maybe 3 volts. In that case it would be a rocket at 18-20 volts, but its life might be short. BSRT had high performance motors of this sort.
Postby TeamMadMarsupial » Fri Dec 30, 2016 10:37 am
Thanks Rich, short life would not bother me if I could get them at a reasonable price. Our heat races are only three laps and our features just 5 laps. I run a lot of set ups that would not last for any type of distance.
TeamMadMarsupial
