The T-Bird is set aside for the moment as work continues
on the Falcon. A hood has been built along with a louvered
radiator cover.
Sanded a angle on the hood to give it a bent sheet metal look and
found some injectors for it so we will be building a box around
them. This is the beginning.
Glued all those pieces together into a box shape
After some cutting and sanding we have a fairly square box to work
with.
At this point, mocked everything up on the car to see what it would look
like. Needs some more work as it is a little high but that will be fixed
once mounted to the hood.
Still much work to do but it's coming along and starting to look like something.
More later
Kevin
