Home Racing World • View topic - HO Trans-Am Proxy ?
HO Trans-Am Proxy ?
Re: HO Trans-Am Proxy ?
Postby Ky.Slot Racer » Sat Oct 20, 2018 4:55 pm
going to send 2 long wheelbase entrees... :mrgreen:
Ky.Slot Racer
HRW Master Modeler
Postby Norman » Sun Oct 21, 2018 11:28 am
Thanks for the RT-HO ordering info, guys!
Rick is shipping me parts tomorrow.
Nice looking cars in the works, bet they will be fast! :D
Norman
Postby TuscoTodd » Sun Oct 21, 2018 12:01 pm
Mark - that ought to make a formidable pair! Those babies are definitely sitting low!
Postby Ecbill » Sun Oct 21, 2018 12:05 pm
Ecbill
Postby TuscoTodd » Sun Oct 21, 2018 12:18 pm
Postby Austin » Sun Oct 21, 2018 3:22 pm
1 TuscoTodd
2 Ecbill
3 Norman
4 Ky.Slot Racer #11 AMX is a short W/B / #76 Challenger long W/B
5 bookie
6 noddaz
7 Z-carfan
8 WB2
9 HomeRacingWorld
10 Austin / Cougar #98 is a short W/B / 1965 MUSTANG #4 raced in 1966 by A.J. Foyt at Sebring
11 Apalmer
Austin
Postby TuscoTodd » Sun Oct 21, 2018 4:59 pm
Austin -
Apalmer is in also.
Postby RichD » Mon Oct 22, 2018 6:29 am
I have never had a problem with JL/AW gears themselves, the real problem is that the cluster gear shaft is a little too short. Often the cars are assembled so that the lower end of the cluster gear shaft does not fit into the hole in the base chassis and the whole works is tilted resulting in a poor gear mesh. The fix is simple enough, first press the cluster gear shaft further into the driven gear, then press the drive pinion up a bit. Now the lower end of the cluster gear shaft will fit in the chassis and the gear mesh will be greatly improved.
Postby Ky.Slot Racer » Wed Oct 24, 2018 8:41 am
Heads up sale !
And if you go to their FB Page there is a 10% off $100 purchase, so 10 chassis cost me $12.14 each shipped..I like the black chassis best.
Ky.Slot Racer
HRW Master Modeler
Postby Austin » Wed Oct 24, 2018 1:54 pm
Thank you, Just put in my order plus some cars.
Austin
Postby Austin » Wed Oct 24, 2018 1:56 pm
Thanks Rich for that info I will be checking mine.
Austin
Postby noddaz » Thu Oct 25, 2018 2:04 pm
noddaz
Postby noddaz » Fri Oct 26, 2018 7:56 pm
Ok, so much for my 1st attempt. Working on the chassis I ended up taking a side path and installed a "bushing" (really brass tube) at the cluster shaft. And also was fed up with the wobble gears that came with this gear plate. So I installed some left over TJet brass gears for the idler and upper and lower cluster gear. And while this gear plate runs (mostly) smooth and fast, not it is not legal for this race. It is a good thing I have more parts...
Scott
noddaz
Postby RichD » Sat Oct 27, 2018 8:56 am
Sometimes the cluster gear shaft hole in the gear plate is too large, it is easy to close that up. The rear axle holes are often too large as well and also need to be closed up. Take a look at this: https://drive.google.com/file/d/1sLokTZ ... sp=sharing
Postby noddaz » Sat Oct 27, 2018 7:46 pm
Thank you for the link!
And I just made a chassis I was working on illegal. I was cleaning some "boogers" off the floor of the magnet pockets to allow the magnets to sit properly. Whoops... At least I found a gear plate that turns freely without binding. Time to put the good gear plate on the good chassis!
And a question, which crown gear can we use? 15 tooth or the Ultra G 19 (?) tooth gear?
Scott
noddaz
