Home Racing World • View topic - TJET Grand Prix Cars on the bench
Re: TJET Grand Prix Cars on the bench
Postby dreinecke » Sun Jul 12, 2015 9:02 pm
You Sir, are a nut! I love those all!!! VERY cool stuff!!!
Postby BIG E » Mon Jul 13, 2015 11:04 am
I may have missed this, but are these beautiful bodies being built for standard Aurora T-Jet application,
or their slimline chassis? Again, sorry if I missed the info earlier in the thread. Nice work! -- Ernie :>)
BIG E
Postby vabchrog » Mon Jul 13, 2015 1:45 pm
Standard TJET Chassis in the Hot Rod/Indy Wheel base configuration
vabchrog
Postby vabchrog » Mon Jul 20, 2015 12:33 pm
The Ferrari 256 and Vanwall masters are 95% done. I have to put a couple of clear coats then clay them up and make the molds. The exhaust are a pain in the but to cast I have to work on the molds. I have misplaced the glass for both of them so I may have to improvise or buy two more diecasts.
Next to the work bench will be the Maserati 250F. I also have a Corgi BRM 25 diecast coming that should be a good starting point for it.
vabchrog
Postby Ralphthe3rd » Mon Jul 20, 2015 3:11 pm
I love that Ferrari, and I'm totally amazed how you make up these bodies from molds, that are made from hacked up Diecast- and other bodies....simply Amazing ! :text-bravo:
Ralphthe3rd
Postby vabchrog » Mon Jul 20, 2015 4:55 pm
For those interested. I take a 1/43rd scale diecast as they are mostly wide enough for the standard TJET chassis and make a outside mold. I then make a thin slosh cast of the mold. Chopping them up is based on how body looks. I try not to have to chop the rear end much as they can be a pain to piece back together.. Sometimes I have to. The Maserati will have to have some taken out. I use a razor saw to cut out the pieces I want. I always shorten the cockpit and take a hunk out. Then I take some out of the nose. I use the same resin the body was slosh cast out of as it sands very easily and with a heavy duty emery board you can rework the patched area fairly fast. I use smooth-on's smooth cast 300Q because it sets up fast, 5mim. I will tack to body together with a little super glue. Then brush a coat of resin after it thickens to the consistency of a thick pancake syrup with some cheap kids paint brushes I get at Walmart. I have a standard TJET chassis that I covered in silicone. I place the body on it and flow resin along the bottom the lengthen the sides to make it appear to sit lower. I use either duct tape on the inside or silly putty when I have it to use a a backing to fill larger areas like the Ferrari Wheel wells were to high. So I filled the area sanded it down and added a panel line. I use a razor saw for most body panel lines. They are getting easier. Maybe I'll do a step bu step on the BRM 25 when I do it.
vabchrog
Postby Ralphthe3rd » Mon Jul 20, 2015 8:13 pm
Ralphthe3rd
Postby vabchrog » Tue Jul 21, 2015 6:42 pm
For those that are interested I have a Yahoo group for my open-wheel tjets projects
https://groups.yahoo.com/neo/groups/openwheeltjets
vabchrog
Postby vabchrog » Thu Jul 23, 2015 4:47 pm
If look side picture you can see where I took some out of the cockpit and took two small cuts along existing seams on rear.
The top view shows the cockpit cut and where I took some off the nose. I carefully cut along the hood front seam then sanded the hood back and continued sanding and fitting till I got it where I wanted. Then I super glued it back then painted some resin along the seam underneath to strengthen it.
Here is a top picture of the Ferrari Maserati and Vanwall.
vabchrog
Postby vabchrog » Thu Jul 23, 2015 4:52 pm
The Maserati's rear end is really high I am going to lengthen it by at least 1/4 inch an try and make it appear to be lower.
Should I take some more out of the rear end? The 1:1 is much longer than the Ferrari.
vabchrog
Postby vabchrog » Mon Jul 27, 2015 10:56 am
Almost done. The side fin molds have to be redone, then paint clear coat and make new outside mold. Slosh cast add body post and make the inside mold.
vabchrog
Postby vabchrog » Mon Jul 27, 2015 7:19 pm
A couple of clear coats and into the mold box. I do think I'm going to make the side fins narrower. What do you all think? I need to do test cast of the glass and see how it fits. The Ferrari, Vanwall and Maserati will all have separate clear glass.
vabchrog
Postby vabchrog » Sun Aug 02, 2015 12:48 pm
Got my Pattos decals and redid the Lola Mk4 its raining and I need to paint the Vanwall and Ferrari and try the new decals. I also want to make a new Brabham BT3 with Patos decals.
vabchrog
