Almost Finished
Re: Almost Finished
Postby kcl » Sat Dec 01, 2012 10:55 am
The car in the background is also now finished
and came out well
Thanks
Kevin
kcl
Re: Almost Finished
Postby kcl » Sat Dec 01, 2012 12:42 pm
Here's something else I've started working on. It's a 53 Studebaker
Started with this
Took 1/8 out of the rear deck to shorten it up
After checking it with the chassis, something didn't look right so I took 3/32 out of the
roof and remounted it.
So this is were it is now kinda mocked up and a start of a hood
Still a lot of work to do yet but progressing
Kevin
kcl
Re: Almost Finished
Postby john56h » Sun Dec 02, 2012 11:39 pm
All three are awesome builds!
What do you use to fabricate the bumpers and nerfs?
john56h
Re: Almost Finished
Postby kcl » Mon Dec 03, 2012 9:43 am
John
Thanks The bumpers and sometimes roll cages when I feel like putting them in
are made from paper clips. Use small and large ones, sometimes straight pins
if I need a small diameter. Most times glued sometimes soldered.
I drill an indent in the chassis for the clip to go into rather than just gluing them on to the
the chassis and sand the glue smooth so the joints look better.
No tricks just a lot of misbent clips and cuss words.
Thanks for asking
Kevin
kcl
Re: Almost Finished
Postby gonegonzo » Fri Dec 07, 2012 8:03 am
The Studebacker is off the hook as well . Show us more hwen completed .
I think your next build should be a bullring oval so you can race these cars .
Gonzo
gonegonzo
Re: Almost Finished
Postby kcl » Tue Jan 01, 2013 9:42 am
Been awhile and the Studebaker is progressing. Chassis is finished and painted
Body is pretty much finished, needs paint but to cold to do it but the car itself
is just about done.
Working on deciding paint color and decals.
Thanks for looking
Kevin
kcl
Re: Almost Finished
Postby kcl » Sun Feb 10, 2013 6:41 am
The Studebaker is now finished. Came out pretty good I think.
Color is Duplicolor Toreador Red metallic with decals
from Polecat Decals. Color is a little darker than pictures
show ( bad lighting ) first pic is close though
Thanks for looking
Kevin
kcl
Re: Almost Finished
Postby kcl » Mon Mar 25, 2013 4:44 pm
Something I finished up over the weekend a little coach that started
life as an AFX panel truck. Cage and bumpers are paper clips, the pipes
and carb stacks are 1/16 brass tube.
Paint is Duplicolor Desert Tan Mica wife picked it guess I should take her
more often.
Also the front wheels were turned down with a Dremel and X-acto knife to clear
the pipes.
Thanks for looking
Kevin
kcl
Re: Almost Finished
Postby HomeRacingWorld » Mon Mar 25, 2013 5:33 pm
Oh...now this one is a doll.
Could one of these be the new photo in the HO Section?
Re: Almost Finished
Postby kcl » Mon Mar 25, 2013 5:51 pm
Sure, pick which ever one you want to use
Would be an honor
Kevin
kcl
Re: Almost Finished
Postby RichD » Tue Mar 26, 2013 5:59 am
JW's HO Speed parts now has front ends for this type of car, they have the right diameter axle so you won't have to drill out the chassis. The front end takes 3/16th wide tires and you can specify the diameter that you want. For a brass front end the part number is E14WP-B-.400, the number at the end is the tire diameter. White plastic front ends are E14WP-N-, black plastic is E14WP-D- and aluminum is E14WP-A- . The front ends are $7.95.
Re: Almost Finished
Postby kcl » Tue Mar 26, 2013 5:48 pm
Thank you for the information on the wheel sets Rich will
have to look into it. Very pretty car by the way.
What size front tires are on the front of yours?
They fit the car well.
Kevin
kcl
Re: Almost Finished
Postby RichD » Wed Mar 27, 2013 6:07 am
The front tires are 0.400 inches in diameter.
Re: Almost Finished
Postby kcl » Sun Mar 31, 2013 6:38 pm
Here's something I'm working on. It's a Pinto from a AFX funny car.
Finished up the chassis today, had to put bushings in the rear axle holes
cause the axle was 0.59 and the hole was to big. Bumpers are finished
and ready for paint.
Cage is built and just needs a little clean up.
There is a driver that goes in there also but he can't go in till the chassis is complete
and assembled.
She's getting there.
Kevin
kcl
Re: Almost Finished
Postby kcl » Mon Apr 08, 2013 6:34 pm
Finished the Pinto up, came out pretty good
Kevin
kcl
