Almost Finished
Re: Almost Finished
Postby TeamMadMarsupial » Sun Mar 01, 2015 8:23 am
As always, lookin great Kevin. Always love to see the detail you put into your cars!
TeamMadMarsupial
Re: Almost Finished
Postby dreinecke » Sun Mar 01, 2015 9:17 am
Simply awesome! I like your mounting method - I don't think I have seen that before.
Re: Almost Finished
Postby kcl » Sun Mar 01, 2015 10:33 am
Came up with that awhile back while working on a 36 ford body. Body was very skinny
and no room for sticky tape needed another way to mount the body.
Kevin
kcl
Re: Almost Finished
Postby sweet » Sun Mar 01, 2015 12:00 pm
All your cars are killer. But this one is DEADLY!
sweet
Re: Almost Finished
Postby kcl » Thu Mar 05, 2015 1:48 pm
Fabrication of the rear framework has started.
This will become the attachment point for the rear bumper. not done yet still a few more
pieces to figure out.
More later
Kevin
kcl
Re: Almost Finished
Postby kcl » Sun Mar 08, 2015 10:37 am
Started on the rear bumper. The two main bars are in
just need to finish it.
Kevin
kcl
Re: Almost Finished
Postby kcl » Sat Mar 14, 2015 9:28 pm
Finished up the rear bumper and framework around the fuel cell. Added some support
bars for the body.
A couple with the body off
Need to start the front end and build a hood to get a better idea of what it will look
like.
All for now
Kevin
kcl
Re: Almost Finished
Postby kcl » Fri Mar 20, 2015 6:31 pm
Started working up a hood. While doing so a couple problems arouse.
One, the notch for gear clearance looked to big and second the gear was
was higher than the hood so a work around was needed.
The solution turned out to just build a small cowl to help hide the gear.
The cowl not only helps to hide the gear but also gives the hood a better look.
It will look better with a set of injectors sticking out of the hood.
Hood is still rough, more work to do yet.
All for now
Kevin
kcl
Re: Almost Finished
Postby DixonJohn » Fri Mar 20, 2015 6:55 pm
Man those cars look good
DixonJohn
"The Mayor"
Re: Almost Finished
Postby kcl » Sun Apr 12, 2015 7:47 am
After some slack time, got back to work on the 40. Cut a hole in the hood for
the injectors and cut the injectors down some and built some air filters out
of some round stock and put them on top.
Driver is cleaned up and injectors need some clean up yet so they can be painted.
Progress is slow but getting there.
More later
Kevin
kcl
Re: Almost Finished
Postby TuscoTodd » Sun Apr 12, 2015 8:44 am
Lookin' good! :D
Re: Almost Finished
Postby kcl » Sun May 17, 2015 6:45 pm
Got back to work on the 40 after some set backs.
Finished the front bumper and added a center piece
to it.
Also started working on some shocks for the front. One side is build still need
to do the other side. Made from a paper clip, some drilled out rod for the caps
and a G-Plus brush spring.
Hope the other side turns out as well.
All for now
Kevin
kcl
Re: Almost Finished
Postby kcl » Tue May 19, 2015 7:48 pm
Finished the shocks off. Still need to clean up the joints yet.
Came out fairly well.
All for now
Kevin
kcl
Re: Almost Finished
Postby sweet » Tue May 19, 2015 8:08 pm
Great work, as usual. Amazing detail and fabrication in something so small.
sweet
Re: Almost Finished
Postby vabchrog » Wed May 20, 2015 12:27 pm
You make me want to go through my resin rejects and re-purpose some as your style modified. Love all your cars
vabchrog
