Home Racing World • View topic - 2019 Can-Am spec sheet
Re: 2019 Can-Am spec sheet
Postby 53BN1 » Mon May 06, 2019 9:19 pm
Hi Rob
Here is my data as per your request
Name/Number: 53BN1 / #6
Country: Canada
Body/Model: Slot.it CS26B/ McLaren M8D
Chassis: Slot.it C26t-60
Motor pod Slot.it Sidewinder 0.5mm offset CH70
Wheels Slot.it 14.8 x 8 front plastic rears alloy
Front tyre Slot.it rubber
Rear tyre Slot.it rubber
Gearing Slot.it 10/34
Motor Slot.it 29K 12volt
Guide Slot.it Wooden track CH07
Weight approximately 90gm +/- 2gm
Ed
53BN1
Postby redlynr » Tue May 07, 2019 5:33 am
Name/Number: Redlynr/#2
Country: USA
Body/Model: Slot.it McLaren M8D
Chassis: Stock
Wheels: Slot.it
Front tire: Slotting Plus
Rear tire: NSR, (SG I think)
Gearing: 10/31
Motor: Piranha 25k
Guide: Slotting Plus
redlynr
Postby FC47 » Tue May 07, 2019 7:38 am
Name/Number: FC47/ 47
Country: USA
Body/Model: Slot.it Chapparal 2E
Chassis: Stock sidewinder
Wheels: Slot.it
Front tire: Worn out glazed
Rear tire: Slot.it
Gearing: 10/31?...weighted...
Can't find the sheet...
Motor: Org end Slot.it
Guide: modified, from stock?
FC47
Postby Smokeio » Tue May 07, 2019 8:22 am
Name / Number – Smokeio #70
Country - USA
Body / Make – Slot.it McLaren M8D
Chassis – Slot.it standard
Configuration - Sidewinder CG Slot Car Pod
Front Hubs - CBD 15x8 racing wheels with the little dots for lug nut detail
Rear Hubs - CBD 15x10 racing wheels with those same little dots for lug nuts
Front Tire - Slot.it zero grip 17x10 narrowed and zeroed over with 20 coats of acrylic polyurethane
Rear Tire – NSR Ultra Sticky Grippers. Trued for 30 days at 3 RPHs bathed in Peruvian Spring Water by some old lady in Italy
Gearing – Oh god I can’t remember…. Maybe 11/36?
Gears – Slot.it gears
Motor – Yes, Gobs of RPM with an MB Slot 26,000 spinner upper
Guide – And another thing I can’t remember. Whatever I had on my bench that wasn’t deep.
Paint – A deep Slot Car Corner Yellow painted with a mop.
Oil – Super lube racing oil and gear lube. The fasted oil in the East.
Tape – CARGOFAST racing tape. This is the real fast stuff used to go faster than GASCARISANUT.
Driver – Iggy Schwartz. I drafted him from the Baja Marimba band after he got kicked out.
Sponsor – Quick Slicks
What did I miss?
Smokeio
Postby Changing-Gearz » Tue May 07, 2019 8:25 am
^^^^^^^^^^^^^^^^^^^^^^^^^^^------- Tough act to follow :o
Name/Number: CG / 25
Country: USA
Body/Model: CG Slotcars McKee Mk10 3DP (prototype)
Chassis: Stock 3DP (prototype)
Motor Pod: CG Slotcars inline 3DP pod
Wheels: CB 14x8F 14x12R
Front tire: PG
Rear tire: NSR
Gearing: for speed (10/tiny crown)
Motor: 25k
Guide: Slot.it
Weight: 82g
Changing-Gearz
Postby DRW21 » Tue May 07, 2019 2:28 pm
DRW21
#35
Thunderslot M6 white kit
Stock chassis, motor (21.5), stock 11-32 gears with a Thunderslot spring kit fitted
Thunderslot grey motor pod
Longer front axle (MRRC) with spacers from Slot Car Corner
Thunderslot alloy rims up front
Parma rear axle bushes
NSR super gripes out back
Otherwise all else is stock Thunderslot
I did try faster motors and different ratios but still couldn't beat the stock running gear
Not sure about the final weight, I just added the lead till it felt right
DRW21
Postby F1Fan » Tue May 07, 2019 10:03 pm
F1Fan
Postby Audi1 » Wed May 08, 2019 4:15 am
Not that the #52 can compare with the #35; because it can't, but it also has the TS spring kit with medium springs located at all 5 pod/body attachment points. Different spring tensions at the different point, but equal tensions on either side of the centerline.
Postby F1Fan » Wed May 08, 2019 9:16 am
F1Fan
Postby Smokeio » Wed May 08, 2019 10:09 am
You reminded me I have to update my spec sheet. If anyone is interested you can get a fargal pin from CARGOFAST Slot Car Racing Products For Adults Racing Toy Cars For Bowling Trophies.com
Smokeio
Postby Cgyracer » Wed May 08, 2019 12:03 pm
Congrats to the top dogs this qualifying......DRW21, Smoke, and Audi1.... Looking good guys! I think I accidentally microwaved my tires 10 minutes instead of 1 minute.....careful Allan, the foam insert might explode at full speed...wear your safety glasses! :dance:
Rob
Cgyracer
Postby DRW21 » Wed May 08, 2019 2:18 pm
Thanks guys, looking forward to race day.
Man that's a great field.
Wish I could be there!!!
DRW21
Postby BARC 1 » Sat May 11, 2019 7:47 am
Thunderslots seem to be very popular
Postby ALS » Sat May 11, 2019 2:36 pm
Car Ti22
Motor SCC
25,000
TIRES NSR SUPER
Chassie CG Slots
Pod CG Slots
Weight 82 grams
Gearing. 14/43 Stock
Motor change and Tires
ALS
Postby GT6 » Sat May 11, 2019 5:03 pm
GT6
Return to 2019 Can-Am Proxy
