Home Racing World • View topic - 2019 TransAm Proxy - Rules and Registration
Re: 2019 TransAm Proxy - Rules and Registration
Postby Audi1 » Thu Jan 03, 2019 1:14 pm
That's a good plan!
Postby CARacing » Fri Jan 04, 2019 1:18 pm
Thanx Allan...more time to prep!!!
CARacing
Postby Doubl-B » Sun Jan 06, 2019 2:00 pm
Allan:
I didn't see it listed. OK to glue and true tires?
thx.
BB
Doubl-B
Postby Audi1 » Sun Jan 06, 2019 3:58 pm
Bob - absolutely!
Postby Audi1 » Fri Jan 11, 2019 7:15 pm
Which screen name goes with Dave Holmes?
Postby 4424ever » Fri Jan 11, 2019 8:19 pm
Sorry about that I was about to send you a message when I saw this post
The PP issues for me must be solved if you finally receive my payment
I canceled the initial payment and resent it. Hope we’re all good :o
4424ever
Postby redlynr » Sun Jan 13, 2019 5:32 am
redlynr
Postby Audi1 » Sun Jan 13, 2019 5:57 am
Yes, thanks for the pick-up; FK-180 long cans are legal for this proxy (correction made in the Rules section).
Postby 4424ever » Sun Jan 13, 2019 10:04 am
The Colgate motor is listed in Robert Livingston’s specs as Legal but the can is not easily identifiable is it considered ok for the proxy :text-thankyouyellow:
4424ever
Postby Audi1 » Sun Jan 13, 2019 11:09 am
If the Colgate motor is either an SC-130 or FK-180 and has a manufacturer's spec of 21,500 rpm or lower, then it qualifies. We don't base eligibility on the specs given in Robert Livingston's New Motor List. Here's what the Rules say: "if the motor is MANUFACTURER RATED at or below 21.5k RPM - it qualifies for this proxy."
Postby Kevan » Sun Jan 13, 2019 1:58 pm
They're all made in China anyway and a digital tacho only costs $10 shipped.
Kevan
Postby DRW21 » Sat Jan 19, 2019 1:42 am
Hi Allan, would it be possible to amend the rim width rule?
The only reason would be to allow more glue on the greater surface area of the rim and tire if the rim is allowed to be 10mm not the 8.5mm seen how 11mm wide tires are permitted.
I don't see it as a performance gain as there would be more rotating mass, just less chance of tires coming loose.
Cheers - Dave.
DRW21
Postby Audi1 » Sat Jan 19, 2019 5:43 am
Hi Dave, Those are the same wheel and tire rules that we had for the ill-fated 2018 Trans-Am Proxy series and since a lot of this year's entries will be based on the 2018 cars, we can't make that change. I do understand the request, but we can't accommodate it this time around.
Postby DRW21 » Sat Jan 19, 2019 1:27 pm
Thanks for that Allan, no worries Mate, looking forward to this one too.
I'll be running a Scaley '70 Camaro, number is yet to be sorted, I'll keep ya posted asap.
Cheers Guys
DRW21
Postby Aloha » Sat Jan 26, 2019 4:54 pm
May I pls change entry from #3 to #7
Thank you
Aloha
Dale
Aloha
Return to 2019 Trans Am Proxy
