Home Racing World • View topic - Any Opinions on AMT Slot Car Kits?
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby Florida_Slotter » Fri Oct 03, 2014 8:55 am
I've seen ads at Hobbylinv for AMT slot car kits for about $32.00. I'm wondering - bargain or not.
Any opinions / experiences gladly accepted.
Re: Any Opinions on AMT Slot Car Kits?
Postby HomeRacingWorld » Fri Oct 03, 2014 8:58 am
OH Hobbylinc...I thought you meant Ollies. $32? I would pass.
The rest is like a Fly chassis. It will work, just rebuild it. IMHO, scrap the gear...slice and dice the chassis and add quality parts.
Mark Thomas has made some great running cars from them by being creative.
Postby goosenapper » Fri Oct 03, 2014 9:05 am
goosenapper
Postby Fubar Motorsports » Fri Oct 03, 2014 9:09 am
Fubar Motorsports
Postby waaytoomuchintothis » Fri Oct 03, 2014 10:39 am
Postby jeepcj7 » Fri Oct 03, 2014 11:30 am
OLLIE'S $14.98
jeepcj7
Postby Florida_Slotter » Fri Oct 03, 2014 1:11 pm
Got a website for Ollie's?
Postby goosenapper » Fri Oct 03, 2014 1:27 pm
goosenapper
Postby Florida_Slotter » Fri Oct 03, 2014 1:34 pm
Drat! Foiled again! Closest Ollie's is about 4 hours away. With my luck they'd be sold out just before I got there.
Postby Florida_Slotter » Fri Oct 03, 2014 2:49 pm
Jeremy,
61 Ford
62 Pontiac
70 Camaro
Thank you very much kind sire.
Let me know how much, with shipping, and I'll send a check immediately.
Postby philo426 » Fri Oct 03, 2014 3:48 pm
philo426
Postby waaytoomuchintothis » Fri Oct 03, 2014 6:24 pm
This is what I like seeing guys. Slot car guys are the best.
Postby Kemtronracer » Fri Oct 03, 2014 9:10 pm
A few specs that I found with these AMT kits:
The axles are a bit smaller than 1/8"
The chassis sits about 1/8" off the track
The motor tachs at about 22K RPM at 12 volts
Kemtronracer
Postby burad » Fri Oct 03, 2014 11:40 pm
There are, I believe, 8 cars in the whole line. 4 of them usually come with aluminum set screw wheels, set screw spacers and a set screw crown: 66 Olds 442, 71 Charger, 61 Galaxie, and 62 Catalina. The other four cars usually come with press on plastic wheels and knurled axles: 57 Chevy, 66 Nova, 70 Camaro, 66 Camaro. If the kit has silver wheels, they should be aluminum. If the wheels are black, they are probably plastic. The axles are 3mm, the same size as Scalextric Sport.
Note that Ollies is also having a big sale on 1/25 scale car model kits, for 8 bucks. Most of those will fit the chassis, and provide you with many more potential cars.
burad
Postby proxieken » Sat Oct 04, 2014 6:25 am
Can someone provide a link to a replacement crown gear? I read the review and it says to replace it, but I have no idea what to use in its place.
Thanks.
proxieken
Return to HRW 1/24 Scale
