Ford Resins
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Ford Resins
Postby Rastas » Sun Jan 13, 2019 4:59 am
I am learning a little bit about this resin casting and I'm going to give it a go a little down the road !
But in the meantime I was hopping that I might be able to perchase some ford resins off someone ????? If so let me know thanks. Rastas.
Rastas
Re: Ford Resins
Postby nhdungeonracer » Sun Jan 13, 2019 9:14 am
Does it have to be resin?
Would model bodies work?
Re: Ford Resins
Postby REL13 » Sun Jan 13, 2019 9:48 am
I see that this is posted on the 1/24 scale. I think that Falcon is a 1/32 scale. If that model you are talking about is 1/32, I would be interested in it, If you have one. REL13
REL13
Re: Ford Resins
Postby Rastas » Sun Jan 13, 2019 10:16 am
Yes that's what I'm useing ,the price of the models are expensive he in Australia , and all I use is the body and a few other bit's the rest is left in the box I keep the motor's to. I thought the resin body's would be cheaper .scale does not matter I have 1/ 24 witch I would like falcon ,fairlane or sprint 1/32 the same.I have both scales.
Rastas
Return to HRW 1/24 Scale
