Home Racing World • View topic - Foam tires for Carrera
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby eAddict » Fri Aug 12, 2016 10:25 am
Anyone successfully replaced the wheels/tires on a Carrera 1/24 car to rubber to run (better) on wood? If so, what did you do?
eAddict
Re: Foam tires for Carrera
Postby Jhardy33 » Thu Nov 24, 2016 5:52 pm
Jhardy33
Postby Dangermouse » Thu Nov 24, 2016 9:00 pm
We use cincyslot and Paul urethane Tyres on our 1/24 Carrera and they go fine on wood tracks we are currently running with the magnets on magnabraid.
If you wanted to buy new wheels they have 3mm rear axle so Plafit or Scaleauto wheels will fit.
Dangermouse
Postby mattb » Fri Nov 25, 2016 8:07 am
Some of our guys have tossed the plastic chassis and built solid brass or H&R chassis and run silicone coated Protrack tires. They like using Cox Chaparral wheels for inserts.
Return to HRW 1/24 Scale
