Home Racing World • View topic - H&R 1/24 Racing at S&S
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby DaveKennedy » Fri May 13, 2016 8:56 am
So it had been far too long since I went to race with the guys and last night the lure of racing 1/24 H&R chassis cars was too strong. We ran a heat of Trans Am cars and a heat of IMSA type GT cars. It was cool to be with the fellas again racing. This is S&S Speedway or as you might know it "Sammy's Garage" 8-)
Re: H&R 1/24 Racing at S&S
Postby HomeRacingWorld » Fri May 13, 2016 8:57 am
Yes sir, great video and track. Looks like a fun time indeed.
Postby DaveKennedy » Fri May 13, 2016 9:02 am
BTW all shot with my GoPro Session and edited on my Ipad in iMovie... for the guys out there that might be interested in the technical info.
Postby goosenapper » Fri May 13, 2016 10:04 am
I actually ran an H&R chassis last night too:
The difference is I ran mine on a digital track. That's a D132 chip with a tiny piece of styrene underneath it to insulate it from the brass, held in place by a rubber-band because why over-think it? It worked. The other modifications included gluing two tiny styrene tubes beneath the front axle to keep the leads from touching it, adding a bit of weight, drilling a hole for the IR bulb, and snapping off the hunk of brass that the leads originally were threaded through. The guide was dremmeled down a bit since in stock form it hit every single track connection. This chassis has PG fronts and H&R silicone rears, driven by a Hawk.
Last night was a test, hence the taped-together Buick Regal body, but it ran very well on the track, and seeing a Regal zoom around the course was simply cool.
Comments from the guys mentioning how smooth it ran was enough for me. The project is moving forward and I soon hope to be able to provide an entire field of early '80's NASCARs. This should be a very nice change of pace to our usual stock D124 racing.
goosenapper
Postby HomeRacingWorld » Fri May 13, 2016 10:11 am
"to be able to provide an entire field of early '80's NASCARs"
Now we are talkin' :)
Postby Z-carfan » Fri May 13, 2016 11:24 am
Triple thumbs up, that is going to be way cool!
Postby Broman62 » Fri May 13, 2016 11:32 am
First off DK...that video is sweeeet!!!
Secondly GN...that chassis and body look awesome!!
Thanks for posting both!!
Return to HRW 1/24 Scale
