Home Racing World • View topic - Tree Supports
Tree Supports
Tree Supports
Postby Junior » Thu May 30, 2019 3:20 pm
I might be late to the game on this one, but if you haven't tried tree supports over regular supports, give them a try. I have typically avoided anything that needed a support due to prior bad luck with trying to separate the print from the supports. I have been playing around with tree supports and they work so much better.
I printed this motor with tree supports and the detail of the exhaust comes out great.
The one on the right is with the supports, the one on the left has the supports removed. Great motor for a modify build.
Junior
Shop Teacher
Re: Tree Supports
Postby Fitzy » Thu May 30, 2019 7:55 pm
Nice I'd like to give that a try where is the file for the engine?
Fitzy
Re: Tree Supports
Postby Junior » Thu May 30, 2019 8:17 pm
Junior
Shop Teacher
Re: Tree Supports
Postby HomeRacingWorld » Thu May 30, 2019 11:10 pm
That’s a nice one. I have not had much luck so I’ll try it. Thanks sir!
Re: Tree Supports
Postby Fitzy » Sat Jun 01, 2019 6:32 am
Thanks Junior how do I size it for 1/32 scale?
Fitzy
Re: Tree Supports
Postby Junior » Sun Jun 02, 2019 7:43 pm
Fizty, I scaled it to 1/32ish in Utilmaker Cura which I use to slice the file for the printer. I kind of eyeballed it to 1/32, I used an existing resin motor for a reference.
The purple one was my first print which came out a little to small so I enlarged it a few MM's.
Junior
Shop Teacher
Re: Tree Supports
Postby Junior » Sun Jun 02, 2019 7:47 pm
I was looking for bodies to print and found this cab on Thingiverse. I printed is with tree supports and the print came out great The best part is the tree supports separated from the cab very easily.
Junior
Shop Teacher
Re: Tree Supports
Postby noddaz » Thu Jun 06, 2019 6:09 pm
:lol: I was expecting something along the lines of stumps or actual tree supports!
noddaz
Return to 3D Slot Forum
