Help creating brims for all body edges?
Postby asmith » Tue Apr 09, 2019 7:59 pm
Working with CURA 4.0 and asking for any help with creating build plate adhesion brim on all edges where body rests on build plate.
In this screen capture from CURA 4.0 only the rear and right side have a brim, and that's the way it prints out as well. With my Ender3 the first layers for front and left side don't adhere to heated plate without a brim.
I reloaded the original download file and found it only has a brim on rear section. Somehow I added the right side brim, but don't know how I did that. I printed the body okay with full internal support on, but wanted to try without support.
Appreciate any help - Alan
BRIM ON REAR AND RIGHT ONLY...
asmith
Re: Help creating brims for all body edges?
Postby asmith » Tue Apr 09, 2019 9:01 pm
Might have found a solution, in CURA I slammed the body down by -1 in the Z axis.
Changing the Z-axis worked to create brims, but without the internal support structure the end of the body posts print mid-air. Time to learn a CAD program to extend the posts. I’d like to make the rear post larger as well.
Alan
asmith
Postby chappyman66 » Wed Apr 10, 2019 11:03 am
Hi Allan,
I used styrene tubing around the rear post...so yeah.
Upload a modification....by all means. Otherwise I can do it this weekend some time.
Postby asmith » Wed Apr 10, 2019 3:38 pm
Tubing - smart! On my first body the rear post broke off completely when taking the “support” out. Don’t have a Dremel right now. If you get to modding it great, but I have to learn a CAD program anyway, leaning towards Blender, what do you use?
Alan
asmith
Postby ccobra » Wed Apr 10, 2019 5:04 pm
If you are breaking off the posts when taking out the support material, print it up-side-down. That's what I did with the Porsche. I found it easier to take the support material off from the outside than to take it off the inside. As far as programs go, I've had better luck adding posts using Inventor but that is only a preference thing. I've had so mixed luck using Meshmixer to thicken the body parts but I still have to take the hand extruder gun out and add material, then sand it down.
ccobra
Postby chappyman66 » Wed Apr 10, 2019 7:33 pm
I haven't taken the time to learn anything as complex as Blender or even the full capabilities of Meshmixer.
The Porsche was done entirely in Tinkercad.
This is how I do it in Tinkercad:
1) Open the body file, and create a copy of the body.
2) Make the post in the body, and a little longer so it goes into the "thickness" of the body.
3) Turn the body into a "hole" and combine it with the post. This shaves the post base in exactly the right shape to fit the body.
4) Move the post to the original body, and once in correct position combine with the body. This should merge it to make a one piece print.
5) Add some bracing at the base, if desired.
If you are breaking posts, try a couple of different settings in your slicer:
The strength of the supports (I run mine at 7-10% or less so they peel out easily)
The separation distance between the top of the support and the body (called vertical offset in Simplify3D). More separation = easier removal, but less support for the actual shape....which matters when you are doing dive planes on the front fenders etc.
Postby asmith » Thu Apr 11, 2019 12:27 am
Thanks ccobra and chappyman66. Printing the Porsche upside while doing the introduction lesions in ThinkerCAD.
Alan
asmith
Return to 3D Slot Forum
Users browsing this forum: No registered users and 26 guests
