Home Racing World • View topic - 1/32 3-lane 3.5" lane spacing timing gantry
Postby PetesLightKits » Sun Jan 13, 2019 3:25 pm
Posted this to Thingiverse...
https://www.thingiverse.com/thing:3354328
Just finishing printing and won't really know how well it works until I assemble and install on my as yet to be made routed wood track (sometime this spring). It uses 3mm IR LEDs. Wanted to share and get comments / feedback.
v3 - changed the mounting holes from countersunk to non-countersunk so that the forces of the screw don't split the mount apart.
Peter
PetesLightKits
Re: 1/32 3-lane 3.5" lane spacing timing gantry
Postby PetesLightKits » Mon Jan 14, 2019 4:18 pm
Printed and assembled...
Opening is about 13.7". Ends are slightly bowed in and will pull apart when mounting. I might adjust the STL file to stretch it out to an even 14".
Detail of the centre section showing the joint and 3mm IR LED. I used ABS solvent. The upper corner where the wire is routed is a bit weak so I will probably run a bead of black hot melt along the inside to add some stability.
Underside of wired upright. Wires will route through a small hole drilled in the track table.
Peter
PetesLightKits
Postby 4424ever » Mon Jan 14, 2019 5:04 pm
That looks pretty good I should replace the rickety old one I have on the road course :music-rockout:
4424ever
Postby SlotCarCorner » Thu Jan 17, 2019 12:44 pm
Nice work - thank you for posting and sharing this!
:text-thankyouyellow:
SlotCarCorner
Postby PetesLightKits » Thu Jan 17, 2019 4:41 pm
PetesLightKits
Postby 4424ever » Thu Jan 17, 2019 5:28 pm
No worries Peter I have a printer (thanks for sharing) but Mosport sounds like a plan :music-rockout:
4424ever
Return to 3D Slot Forum
