3D printed body....need window help!
Postby racer1h » Sun Dec 02, 2018 6:57 am
car I have always wanted-Nissan GTP, is now my first printed body (work in progress). I need advice on making windows please. (or links)
racer1h
Re: 3D printed body....need window help!
Postby Changing-Gearz » Sun Dec 02, 2018 9:45 am
If you want a proper fit - You will need a vacuum forming machine and a plug/buck/mold to pull some clear sheet over.
If you can trim down the model to windscreen area - you are almost there once you print that for a plug.
The plug should include the two side windows and the inside of the roof - so you can glue it in - and the rest should pop into the window opening
I'd try to print that without the windows if you can..... Then you have the opening shape for the glass area etc...
Otherwise - You may find a clear plastic bottle that has almost the same curvature and trim it up to fit
Nice model BTW... Did you make it of find it?
Beer and painting don't mix!
Changing-Gearz
Postby racer1h » Sun Dec 02, 2018 11:11 am
Thanks....I printed it ......I dread the masking!
Where is that body from.
racer1h
Postby Changing-Gearz » Sun Dec 02, 2018 12:26 pm
I made the body from semi-scratch in a CAD tool.... Projections from photos and drawings
Changing-Gearz
Postby racer1h » Sun Dec 02, 2018 4:09 pm
great job!!
racer1h
Postby PetesLightKits » Sun Dec 02, 2018 5:07 pm
Ummm... IIRC in reality that car actually used a Porsche 962C windscreen, so... I would try a Slot.it clear parts pack for the 962C.
Peter
PetesLightKits
Postby Wobble » Sun Dec 02, 2018 6:11 pm
If Porsche 962 is the answer an old Scalextric 962 might make a good donor or at least a buck to vac form with.
Wobble
Return to 3D Slot Forum
