Home Racing World • View topic - 69 T/A Testing and tuning.
Let's build the big ones!
Postby btaylor » Fri Sep 14, 2018 7:16 am
Putting the final tune on this one. Might have to be one of my entries! I blew the crown apart on the second sub 8 second lap! On my track, any car that can run below 8.00 sec's is a mover. this one is built on a very old H&R Chassis with a jaws motor. Just a heads up, I was running some urethanes during set up, and was running around 8.450- 8.525. I put on a new trued and glued set of Trifecta's, and first lap went 7.989! more body adjustments, and more trueing of the front tires should net some mid 7's I believe. You guy's better step it up! this ones hot!
Re: 69 T/A Testing and tuning.
Postby TuscoTodd » Fri Sep 14, 2018 8:18 am
Looks like too many hole shots there Bob!
Great looking entry and great to hear about how well it likes the new rubber! :D
Postby btaylor » Fri Sep 14, 2018 8:36 am
Postby TuscoTodd » Fri Sep 14, 2018 10:24 am
Must have gotten some "wrinkle" to those sidewalls hooking up that hard!
:D
On a related note - how do you like the Jaws in comparison to the Hawk?.
I haven't build anything with the Jaws yet and have a couple that I picked up in a previous SCC order and was kicking around swapping one into either the Camaro (or the Challenger that I am hoping to build next.)
Any thoughts on how their manners compare in the heavier 1/25 scale cars would be appreciated!
:D
Postby arroldn » Fri Sep 14, 2018 10:38 am
Has there been a minimum weight set for these cars? I didn't see anything regarding this in the rules section.
arroldn
Postby TuscoTodd » Fri Sep 14, 2018 10:41 am
Bob - speaking of weight - I am assuming any added lead needs to be "inside" the chassis (not below) - correct?
Postby btaylor » Fri Sep 14, 2018 11:05 am
Todd, we didnt state in the rules, but i think it might be a good idea to keep it inside. Just for the track owners sake. Personally, i dont care if its secured to the bottom.
Postby btaylor » Fri Sep 14, 2018 11:06 am
Postby TuscoTodd » Fri Sep 14, 2018 11:52 am
Postby Z-carfan » Fri Sep 14, 2018 12:32 pm
So on the subject of weights, how much do you put in a 124 car? This H&R is a new chassis for me so unsure of where to start.
Postby btaylor » Fri Sep 14, 2018 12:49 pm
Postby TuscoTodd » Fri Sep 14, 2018 1:15 pm
Bob - Appreciate the details on the attributes of each! The Hawk has been my go-to for many a proxy and it is what we are now using in our "Spec Womp" class at the commercial track - so have a pretty good feel for what it seems to like / dislike. Now whether to dip a toe and Jaws in the potential second build... decisions, decisions, decisions...
:think:
Postby btaylor » Fri Sep 14, 2018 1:19 pm
Todd, if you building two cars, try the jaws. If you dont like it, or the cars dont run equal for you after the proxy, i'll swap you a hawk for it. Win/win.
Postby TuscoTodd » Fri Sep 14, 2018 2:11 pm
Bob - assuming that the Camaro continues to go together as smoothly as it has been, I plan to move forward with building a '72 Challenger based off of this kit:
(this is the one that I said that I needed to do some "hood" work to to make it look appropriate)
I have another SCC order coming with an added chassis - so things look pretty promising for a potential "dual entry" from here and if that is the case, I will outfit the Challenger with the Jaws motor to try it out. :D
Postby btaylor » Fri Sep 14, 2018 2:26 pm
Nice choice! Those mopars make great handling cars.
Return to Taylor 1/24 TA Proxy 2018
Users browsing this forum: No registered users and 34 guests
