Delete, not going to make it
Postby Ky.Slot Racer » Thu Oct 12, 2017 6:55 pm
Chassis under way
Last edited by Ky.Slot Racer on Sun Dec 03, 2017 8:32 am, edited 4 times in total.
Ky.Slot Racer
HRW Master Modeler
Re: Showdown Modified
Postby mattb » Thu Oct 12, 2017 7:39 pm
Mark, I always learn something from your work. Keep posting pix as you solder the chassis together. Are you using two motor brackets permanently or just to align the front axle? I've seen guys use two brackets as you have them positioned as permanent parts of the frame.
Years ago, many years ago, when we first started talking slots on AOL, we had a hobby subfolder that was slot cars. One of the guys, Dave England, had brass front and rear chassis brackets die stamped and bent. They were a god send for scratch building. I wonder what the cost would be to do that again. As many guys as build, I'd be surprised if you couldn't pre-sell whatever a minimum order would be. I think Dave may be a member here or check in occasionally.
Postby HomeRacingWorld » Thu Oct 12, 2017 7:54 pm
Uh huh! This is going to be a hotty.
Thanks Mark, another fun to watch come to life.
Postby Ky.Slot Racer » Wed Oct 18, 2017 6:48 pm
chassis is a roller now, next up, side rub bars/body mounts then assemble both cars for some fitting/tuning before clean up and body works.. :D
Ky.Slot Racer
HRW Master Modeler
Postby HomeRacingWorld » Wed Oct 18, 2017 7:24 pm
Nice...diggin' it.
Postby Ky.Slot Racer » Mon Nov 06, 2017 3:36 am
Geez what a cluster.... this has been, starting now on body #3 . Body #1 32 ford snap kit was 2low in my eyes to fit with the theme of the race. body #2 pioneer mustang was coming along, then I made a cut in the body that just didn`t look right afterwards. Now body #3, well maybe it will be the charmer. On the good side, I am clearing out some old parts bin items :text-thankyouyellow: very much !!
Ky.Slot Racer
HRW Master Modeler
Postby HomeRacingWorld » Mon Nov 06, 2017 10:12 am
LOL some days are like that. Been making a mess down here as well. Want a good deal on some blems? hehe
Postby Ky.Slot Racer » Wed Nov 08, 2017 7:17 pm
Harry,
just for the record this has already been measured. SO NO NEED TO WASTE TIME DOING IT THERE........OK ;)
Ky.Slot Racer
HRW Master Modeler
Postby Ky.Slot Racer » Wed Nov 08, 2017 7:44 pm
BTW, nothing in the rules about this, so I`ll just leave it right here... :whistle:
Ky.Slot Racer
HRW Master Modeler
Postby HomeRacingWorld » Thu Nov 09, 2017 6:26 am
Looks pretty good to me. :dance:
Return to ORW Showdown Series 2018
