What an LMP/GT/F1 Proxy might look like.....
Postby Cjent » Sat Aug 09, 2014 8:41 am
These are the Rules for the 1/43d Scale LMP, GT and F1 Road Racing Season. No deviation is allowed and if it isn't in the rules you cannot do it. (This JUST a proposal!) :text-thankyouyellow:
________________________
F1:
Cars eligible are SCX Compact F1 and Carrera GO!!! F1 cars only.
General Rules below apply, except stock chassis only. Motors are open.
__________________________
LMP Class Car Rules:
LMP.a) Body must be an open or closed cockpit LMP class car which raced during the years 2009-2014.
LMP.b) Chassis: Carrera GO!!!, SCX, Artin, Ranch Design, printed or "homemade" chassis. Wheels, tires, gears, axles, guides, braids, wires, bearings, and fasteners may be modified or replaced by any manufacturer's parts.
LMP.c) Motors are open. Motors which trip overload protectors, slow other cars on the track, or cause other problems due to excessive current draw, will be excluded from racing.
GT Class Car Rules:
GT.a) Body must be a two door, closed cockpit car as raced in any GT series during the years 2009-2014, including ACO/LMS, Pirelli World Challenge and TUDOR, FIA GT (2 & 3),TUDOR United Sports Car Challenge, Pirelli World Challenge, Japanese Super GT Series, ADAC GT Masters, GT Open Series, Belgian GT and FFSA GT Super Series. This includes GTLM, GT2 and GT3 cars only.
GT.b) Chassis: Carrera GO!!!, SCX, Artin, Ranch Design, printed or "homemade" chassis.
GT.c) Motors are open. (Same rules as LMP)
General Car Rules (Applies to all classes):
G.a) Injection molded or resin bodies and vacuum formed bodies of 1/43d scale (See F1 rules for exception!).
G.b) Any 1/43 wheels from Artin, Carrera Go!!!, Jiada, SCX or Ranch Design (no 1/32 scale wheels)
All vehicles must have 4 tires that simultaneously touch the track while resting in the slot.
All 4 tires and wheels must be covered by the body assembly when looking at the car straight down from the top. No variance allowed.
All tires can be trued. All tires can be glued onto rims. Front tires can be coated. No tire goo, glue or other similar additives.
G.c) Guide may not project beyond body when aligned for straight, viewed from directly above.
G.d) All wheel drive, and multiple motors, may be used only if the actual car used them.
G.e) Cars must have sufficient ground clearance to permit free running without contacting track. Cars which drag on track will be excluded.
G.f) Clear window material must be used where the real car has clear material.
G.g) Racing numbers must be visible in three places on body. Bodies may be painted in fantasy or realistic liveries.
G.h) Headlights and tail lights are required for GT & LMP cars, but are not required to actually illuminate. (May be painted in realistic manner where they appear on 1:1 car.)
G.i) Rear wing must be in place if actual car was raced with wing, in the class in which it is entered.
G.j) Interior must include, at minimum, a 1/43d driver on plate or shelf in the proper position for the car. Rear shelf is required under rear window, if 1:1 car has rear window. No mechanical components can be visible, including motors. If vac-formed, must be of reasonable detail and proportion. Paper drivers are not permitted.
G.k) Tires may be of any material, but must be black. Clear finish may be applied to front tire tread area. No chemical treatment (such as oil soaking) is permitted.
G.l) Entrant's name must be written on underside of chassis in paint or Sharpie.
G.m) Magnetic downforce will be checked by table provided by JXR, and may not exceed 30 points.
The allowed magnets:
Ranch Design barrel mag - 7 points
Artin standard half size - 9 points
Artin standard full size - 13 points
SCX Compact - 20 points
Carrera Go!!! - 24 points
Deegan HH Anti-Gravity - 29 points
6mm x 6mm x 1mm neo-mag (part # M0620) - 75g (15 points)
5mm x 5mm x 0.9mm neo-mag (part # M0517) - 35g (7 points)
The number of magnets you can use will be based on the points assigned to each magnet.
Please PM me for where to get magnets, if you do not know.
G.n) Carbon fiber is not permitted in vehicle construction.
G.o) No braid additive, juice or goo.
If it does not say you can, you can't!
TRACK RULES:
Track must be a road course, have dynamic braking and be capable of running at least 15 volts with minimum of 3 amps per running lane available. Race will be run at 15 or 16 volts at track managers discretion. Best 20 of 25 laps in each lane and please post fastest lap for each class as this is worth 1 point. Plastic tracks only, unless you have a wood track with metal braid for magnetic downforce.
Tracks must have adequate safety fencing to prevent excessive car damage. A picture of any track not already approved must be provided. Track must be spotlessly cleaned before your race. Cars are relying on traction and magnet downforce.
ENTRY RULES & FEE:
Each entry will be $15.00 for each car (one car per class) for US. $6.50 for Canada and Euro entries (Cost of postage). No more than 1 car entry per class per person (team) (total of 3 cars, i.e. 1 GT, LMP and 1 F1).
Entry fees will go toward shipping and the remainder will go to the Wounded Warrior Project. Cars received at race 1 without payment of entry fee will not be raced!
No late entries. Cars must arrive in time for the first race at HPR for technical inspection.
Bodies eligible for GT & LMP classes:
GT
Audi R8 LMS GT Ranch Design vacs and Kyosho
Aston Martin DBR9/DBRS Ranch Design & Kyosho
Aston Martin Vantage by Carrera GO!!! & Patto
BMW M3 GTR GTLM & Z4 M CoupeGTLM & GT3 Patto has these and there may be some leftover from JJ Slots and others.
2010-14 Camaro GT3 including Pirelli WC, TUDOR GTLM and GTD.
Corvette C6-R GTLM & ZO6-R GT3 Ranch Design, Patto and Kyosho
Ferrari F430 & 458 GTLM & GT3 (Carrera GO!!! Ferrari 458 GT requires addition of rear glass) Carrera GO!!!, Patto and Ranch Design
Lamborghini Gallardo GT3 Academy Kits, Patto & Ranch Design
Mercedes Benz SLS R GT3 Ranch Design & Patto
Mustang GT (2009-2014) Ranch Design, Patto and Academy kits
Nissan 350/370Z GT3 (Carrera GO!!! with a proper rear wing) and R35 GT-R GT3 Patto, Ranch Design & Kyosho (w/rear wing added)
Porsche 997 GTLM-RSR & GT3 (Carrera Cup body) Carrera GO!!! & Kyosho (w/rear wing added)
2012 Viper Comp Coupe GTLM & GT3 Carrera GO!!! and Patto (Others will be coming)
LMP
The below can be made from the Porsche Spyder body (Carrera GO!!! & Ranch Design vac) with paint & decals:
Porsche RS Spyder
Acura ARX-01B & 02B
Audi R10/R15 TDI (Driver moved to left side)
Creation CA06H Judd
Lola B06/10
Lola B07/10
Pescarolo-Judd/Mazda
And many more!
These cars can be made from the Carrera GO!!! Peugeot 908 body or JJ Slots LMP Coupe (Needs windows) & Ranch-Design LMP Coupe.
Audi R18
Lola Coupe (B08/B10) Aston Martin/Judd/Mazda/Toyota/Nissan
Toyota
Dome 102/3
and others now running.
The best place for inspiration for the LMP cars is the TUDOR, WEC and Le Mans websites galleries.
Make sure you read all the rules!
Carrera, SCX, Hot Wheels, Ranch Design, Kyosho and Patto have current bodies. Carrera, and SCX bodies must have glass and a driver added, as do all. Ranch Design has glass for Carrera GO!!!
Cjent
Re: What an LMP/GT/F1 Proxy might look like.....
Postby Dodgefarmer » Sat Aug 09, 2014 11:00 am
Couple Q's.
(1) Would the printed chassis be considered the same as a RD/homemade chassis ?
(2) How many points are the Kyosho mag?
Randy
Dodgefarmer
Postby Cjent » Sat Aug 09, 2014 11:17 am
Great questions, Randy!
Printed chassis are under home made,now but I think I need to be more specific.
Results on DSlot43 mag will be forthcoming.
Cjent
Postby transam6870 » Sat Aug 09, 2014 1:44 pm
Will those of us that make our own tires and rims be permitted to do so? I know you had mentioned ranch but just asking.
transam6870
Postby Cjent » Sat Aug 09, 2014 3:35 pm
Yes... If the tires do not gum up the track surface. :lol:
Cjent
Postby transam6870 » Sat Aug 09, 2014 4:14 pm
Awesome, the tires I make are urethane.
transam6870
