Home Racing World • View topic - 4TPR - leg 2 @ the Desmo - pics and comments
Postby pfuetze » Sat Nov 23, 2013 3:57 am
the cars arrived and already had some test laps. Drive are stating that the grip on the Desmo improved a little, also the copper tape seems to burnished down new, so good lap times should be possible.
track crew is exhausted after the necessary burnishing session after the broken water pipe. tape lifted due to hot conditions in the basements and dry air from the drying machines in the house. But now everything´s fine again and the track´s ready to run :D
Re: 4 track proxy race - leg 2 @ the Desmo
Postby LloydL » Sat Nov 23, 2013 7:54 am
Looking good Peter, as always! I think my Morgan's roll bar looks a bit odd in these photos though! lol.
Regards, Lloyd
LloydL
Postby Datto » Sat Nov 23, 2013 9:58 am
Looking great, Peter! Again, quite the varied field! :)
Datto
Postby pfuetze » Sat Nov 23, 2013 4:33 pm
pictures and commentary will follow tomorrow!
A really great race, gentleman, thanks!
How are the overall standings calculated, i can´t remember, sorry ...
Postby pfuetze » Sun Nov 24, 2013 7:17 am
Trackcrew has been slacking a little lately. Some styropor from the noise protection in the ceiling has fallen down, through the holes made for the drying machines after the broken water pipe. Track below looked like after a hailstorm. Hail balls the size of footballs polluting the track already caused some serious crashes in an area where it´s normally safe for the bystanders.
After setting the trackcrew with some bribe to the place, they cleared it and the race could start:
Track is cleared, grip level has been up to very high level, some cars already cornering on 2 wheels. Driver is equipped with more than enough Espresso and Mark Knopfler is singing about the Speedway in Nazareth ...
#1 Betz - Porsche 550
12V 90 ohm
small, narrow and way to much play in the axles
a nicely detailed small car, quite funny after i found the rythm of it.
The left rear tire decided at the end of the race that it can leave it´s place, wanting to show that tire glueing makes sense after all.
The little car lives permanently on the edge of a barrel roll, a roll cage would suite the driver ;)
#2 Lloyd - Bugeye Sprite
11V 45ohm
The guide is sitting high up in the chassis, way too much play in the front axle and untrue front tires.
The sprite likes to jump out of the slot, but it is really nicely detailed, driver figure and roll cage are really nicely done. Very quite gears and awesome end speed, good brakes. This car really has some potential, but nees a little work on the front end.
Nice little car with good fun factor.
#3 Betz - BMW LMP
14V 45ohm
After a small drop of oil in the rear end, this heavy car (diecast!) becomes much quieter. Unsealed front tires add additional riot to the front end in the curves.
It´s really fascinating that all those glue points and soldering points are holding together. In fast corners, this car is really quiet, but as soon as slow speed turn comes in sight, it begans to jump and vibrate violently. Quite good to drive, but i can´t figure out why it´s behaving like this in slow turns.
Looks nice for a ghost car without a driver figure.
#4 Lloyd - Morgan
12V 25ohm
A nice and good running car, very quiet, only the singing of the gears is audible. Needs much attention in slow speed corners, but absolutely stable in fast corners. The front right tires is a little in the air, maybe this is causing the handling problem. Or a little too much on the front tires? In the last tight right corner this little car was on 2 wheels minimum 10 times.
It loved lane 3, wonderfull constant laptimes, looks like it the combination of turns way better than on lane 1.
#5 Datto - Camaro #9
9V 25ohm
May i keep the camaro? Please!
Quiet, powerfull, great handling.
The printed chassis and the swinging body mounts seem to work awesome, even with powerfull Fyrebox-1 motor. Also the mostly not so quiet Ranch gears are impressively quiet.
Paint and decals are perfect. One of the nicest cars i´ve ever been allowed to drive! Handling like a dream!
#6 Roland - Camaro #4
A fantastic car to drive, takes much pressure without even blinking. Wonderfully constant to drive. Directly compared to the powerfull Fyrebox-1 motor, this motor seems to be a little weak and geared way longer. The Camaro gets its speed in the corners, center of gravity being way lower than in Marc´s Camaro. Great to drive and really fast.
Great handling car and really fun to drive.
#7 Datto - Mercedes
13V 45ohm
Running quiet and being heavy. Lost the wing at the end of the training session, sorry. Also the windshield came off after trying to enter turn 1 with too much speed. But no problem for some really fast laps. Being heavy the car is not so easy to judge and not easy to get constant speed out of it. Needs serious concentration.
In heat2 on lane 3 suddenly there was a scraping sound. A short inspection revealed a slipped crown gear. Pushed it back into position and off we go again. Sadly, 4 laps later, the crown slipped again. The track crew towed the car in the pits and the mechanics crew decided to try to end the race with a little less speed and reduced power. Without being pushed to the limit, the Mercedes came throught the 2nd half of the race.
Now an owner´s decision is necessary how the handle the slipped crown problem for the next race.
#8 Peter - Porsche
14V 45 ohm
not as quiet as the other cars, maybe not as nice as the others, but fast. Reacting very direct to the controller input. Drives like being glued to the track. Very light.
I´m satisfied with the driving of this one :)
Thanks for letting me drive this cars, gentleman, it has been a real pleasure! Congrats to the podium!
cheers,
puddle dude
Re: 4TPR - leg 2 @ the Desmo - pics and comments
Postby Datto » Sun Nov 24, 2013 10:39 am
Thanks for hosting, and thanks for the write-up. And congratulations, Peter! :clap: :clap: :clap: Not sure what to do about the Merc. :|
Datto
Postby OldDogMotorsports » Sun Nov 24, 2013 10:54 am
congrats and a great write up PD! :music-rockout:
OldDogMotorsports
Postby LloydL » Sun Nov 24, 2013 1:12 pm
You set the standard for 1/43 proxys Peter! Terrific event and great write up and photos.
Congrats to the winners and to the other entrants, they are all nice builds!
Regards, Lloyd
LloydL
Postby micyou03 » Sun Nov 24, 2013 7:03 pm
Congrats Pfuetze. Nice coverage, great pics. looks like great fun.
micyou03
Postby transam6870 » Mon Nov 25, 2013 12:26 pm
Great job Peter. Nice pics. Looks like you had a good turnout. I really like that 70 Camaro lol.
transam6870
Postby Cjent » Tue Nov 26, 2013 12:35 pm
Terrific pictures and description of cars and there strong and weak points, Peter!
Congrats to all!
Cjent
Postby pfuetze » Tue Dec 03, 2013 3:34 pm
Thanks for your kind words!
here are the overall standings after 2 of 3 races (summary based on the actual Formula 1 point system):
The cars are on their way to Roland (and back to Marc).
Postby LloydL » Tue Dec 03, 2013 5:38 pm
Thanks for the results Peter.
Whoops, I must try harder for the Pronomag!
Regards, Lloyd
LloydL
Postby dreinecke » Tue Dec 03, 2013 8:23 pm
Great looking track and cars!
Postby Blacktop Disciple » Thu Dec 05, 2013 3:12 am
Looking forward to getting into this proxy racing. Lovely looking cars and an exciting looking track.
Blacktop Disciple
