50 bucks out the window
Postby OL Mike » Mon Jun 24, 2013 7:21 am
This Artin Wireless super express that I got from K mart is a fine slot car track. Lot of fun to drive. I like way the cars are well detailed.. I can work this track into my other Artin track. I took one car completely apart just see how it runs. The car is easy to work with I fine that this track and cars runs better than other Artin that I own. Only draw back is that they don't have is not enough track to run cars on. But that ok I got a lot of Artin down in my basement. Maybe over 200 feet I like the fact the controller don't get hot. Its takes 3 triple A batteries to make the infra-red transmitter work. Now I can run the cars on any track that I can hook up 8V up to. I found a piece of track that fixes it so you can run your car on ether side of track Image
Last month I did all kinds test to how much it could take I burn the controllers in the cars upYes I burn up 50 bucks now you ask why This is so that if someone ask about track I could tell them the in outs of slot car set I know for fact that the artin track can be used with my other track also that it come with a 8 volts transformer that you can run the cars on a bigger track if use the right voltes. I think that if had use my artin track in a normal manner that can result in having hours of fun
by OL Mike;
OL Mike
