Home Racing World • View topic - Infrared slot cars
Infrared slot cars
Infrared slot cars
Postby OL Mike » Mon May 13, 2013 12:34 pm
Image So I took some time to find out more about infrared IR) light is a wavelength of energy that is invisible to the human eye. The most common source of this energy is heat; objects can have their relative temperatures measured by how much of this energy they give off. Lower wavelengths or "near infrared" — closest to the visible light color red — are not hot, and are often used to transmit data in electronics. A remote control, for example, may use a particular wavelength of near infrared to communicate with a receiver, sending pulses of light that transmit a signal to the device, telling it what to do. This how the car works so I took the time and change the body out 53 Bel air chevy chop coup that I had got in a trade I had to extend the fronts so the wheel would fit right It ran grate until I put the body on the remote control work on 3 feet instead 0f the 12 to 15 feet away Image ImageImage
OL Mike
Re: Infrared slot cars
Postby pfuetze » Mon May 13, 2013 1:07 pm
maybe the metallic paint is shortening the IR reception length?
Postby mfogg » Mon May 13, 2013 3:28 pm
mfogg
Postby Cjent » Tue May 14, 2013 6:26 am
Cjent
