Home Racing World • View topic - aftermarket tire question
Re: aftermarket tire question
Postby HomeRacingWorld » Sun Sep 16, 2012 11:06 am
I turn the tire inside out and use a small nail clipper. I force the excess inside between the "jaws" and snip!
Postby pfuetze » Sun Sep 16, 2012 2:15 pm
did you remove the play in the rear axle?
i always do it with a small drop of CA glue near the bushings. turn by hand till it hardens. and keep turning till the axle is running totally free again. eliminates the last chatter normally.
It´s also way better to glue the rear tires to the rims, especially with soft aftermarket tires.
Peter
Postby Cjent » Sun Sep 16, 2012 3:24 pm
Cjent
Postby Broman62 » Sun Sep 16, 2012 6:12 pm
Postby HomeRacingWorld » Sun Sep 16, 2012 6:26 pm
Yes, wheels can be drilled/tapped incorrectly. They could also be wobbly/bent.
The fix depends on you.
I have seen the wheel hubs filled with styrene rod, glued, sanded and then re-drilled.
Me? I simply order good wheels and keep the old in case I need them for inserts. Then again I race non-mag on wood. Anything not right will show itself FAST.
Sometimes check the front wheels. If the fronts are supporting the weight of the car, then they better be round. If not? More "hippy hops".
Then there is the axle itself. Could be bent.
Then there is the bushings. How do they fit the axle? Too much slop and you have that "hotdog in a hallway" effect. The axle bounces around inside the bushing causing...you guessed it, hippy hops.
Many variables cause this issue. All you can do is closely inspect your car and check for anything out of round and start working from there.
Postby sirslotsalot » Mon Sep 17, 2012 8:22 am
Bruce,
In addition to all the good tips mentioned, a very thin film of Gorilla glue on the hub will help secure the tire. Gorilla glue does expand when it dries so keep it thin. Gorilla glue is good for bonding most dissimilar materials. Works well on re-fastening plastic hubs to axles also. Hope this helps.
Kihm
sirslotsalot
Postby sirslotsalot » Mon Sep 17, 2012 10:29 am
Bruce,
After reading this post a little further, I believe you could install brass bushings to help take out the "slop" in the rear axle. I think Lib/Ranch design stocks them and they don't cost much. Hope this helps also.
sirslotsalot
Postby HomeRacingWorld » Tue Sep 18, 2012 8:00 pm
"Also seem like the inside edges of the rear tires should be rounded off instead of square."
Yes, that is correct. Use some fine grit sandpaper and hold it against that inside edge and give it a round contour.
You are getting there :)
Postby sirslotsalot » Tue Sep 18, 2012 8:11 pm
Harry is a pretty resourceful guy. What other hobby can you fix tires and do your nails at the same time? Pearls of wisdom from the Wise one.
sirslotsalot
Re: aftermarket tire question - update
Postby pfuetze » Tue Sep 18, 2012 11:58 pm
Postby Capn Jodi » Wed Sep 19, 2012 10:21 am
Capn Jodi
Postby pfuetze » Wed Sep 19, 2012 2:49 pm
soldering wires directly to the braids offers a good point for breakage.
i like the SCX compact solution. The guide turns really free and doesn´t influence the sliding.
what i really don´t like are stiff motor wires, like they come originally on the DSlots. Really soft measuring cable are just right, everything else - too stiff IMO. But this only applies for NoMagnetRacing.
