Carrera 1/43 - Create pitlane
PostPosted: Fri Apr 27, 2018 11:17 am
by Rinkrat99
Hi all
Was searching and searching and could only find the Carrera 61618 Mechanical Lane Change Section as potentials for creating a pitlane for refueling. Not sure if a Carrera 4200x Digital Lane Change (Right and/or Left) could be used either.
Has anyone tried this on a 1/43 scale setup? 1st issue is what track is available and then 2nd would be to activate the Analog flapper via a digital signal using some type of solenoid or simply use a Digital Track.
Thoughts?
Re: Carrera 1/43 - Create pitlane
PostPosted: Fri Apr 27, 2018 5:50 pm
by -Nimrod-
Hi RinkRat99,
If your cheap like me, I made my own pit entry back in the day when I was running on Artin 1/32 track.
very easy to work with the hard plastic track.
never got the flippers running though.
NimROD
