by BARC 1 » Sun Dec 17, 2017 1:21 pm
The Lola is less bulky in the back end. It does however mean the motor is moved forward to allow the shell to fit. I am using the Mineabea motor ( 10x 10 x18)as it has a long shaft allowing this to occur.
The other March shells are big enough to take a short shaft motor sitting aft.
The chassis for these cars are well handling. You almost can not deslot them. The rear wheels may break loose, but the low COG has them staying in the slot. I may get one to your proxy in February
