New Carrera GO Plus (+)
Postby MikeySlotCars » Tue Jan 10, 2017 1:33 pm
Carrera have something new coming out the GO+
--> http://www.carrera-toys.com/goplus/
Features
--> http://www.carrera-toys.com/goplus/#features
I think the language is Germain? (use Google translate)
Anyhow that was posted on a French forum so I figure I past it on...
Looks like it's for Analog system it doesn't say anything about been Digital maybe that will be next with more options?
Mikey
MikeySlotCars
Re: New Carrera GO Plus (+)
Postby pfuetze » Tue Jan 10, 2017 2:26 pm
Hi Mickey,
the system is analog.
It offers the possibility to run a ghost car on one lane.
i ordered one box with the go!+ system to give it a try. I want to build the ghost car lane into the Desmo.
The controllers are strange - i measured 12kOhms resistance.
With a magnet car (i built an oval), the system works.
A car without magnet did not work to well, as the controller did not respond too well. i could press it very wide until the car even started to move - normally a sign of too high controller resistance.
will report later for the use on the Desmo. The plastic track offered too less grip for magless cars.
Postby pfuetze » Tue Jan 10, 2017 2:29 pm
Postby MikeySlotCars » Thu Feb 09, 2017 10:49 am
Bump!
MikeySlotCars
Postby pfuetze » Fri Feb 10, 2017 1:36 am
okay, i messed up with more infos ;)
the system is working with a pwm module, therefore the controller with 10.8 kOhms. no way to easily exchange the controllers.
controlling the cars is awfull, with or without mags. the cars only start to move if you already pressed down the trigger 80% of its way.
i stopped trying to integrate the sytem in the Desmo due to this.
