Home Racing World • View topic - Hogging out window techniques?
Postby nerfbarz » Sun Dec 04, 2016 2:15 pm
nerfbarz
Re: Hogging out window techniques?
Postby HomeRacingWorld » Sun Dec 04, 2016 3:15 pm
Dremel and milling bit. Fine tune angles with small file.
Postby BARC 1 » Sun Dec 04, 2016 5:59 pm
Nice find. You could almost leave the windows in the Van and only remove the glass in the cab. As Harry mentioned I would use a dremel with care and then use a file
Postby nerfbarz » Sun Dec 04, 2016 6:51 pm
All good ideas!
Thanks,
Nerf
nerfbarz
Postby pfuetze » Mon Dec 05, 2016 1:10 am
drill bit, multiple holes, file afterwards ...
much work stay, however you do it...
for a nice and clean result, small files are the way to go i think.
Postby studioRS » Mon Dec 05, 2016 7:37 am
Least intrusive method I use is to heat up a #11 xacto blade and use the normal sharp side. Like a hot knife through butter.
studioRS
