Home Racing World • View topic - Suggestions?
Suggestions?
Suggestions?
Postby dc6287 » Wed Apr 06, 2016 9:09 am
What would be a good plan for adding a bit more border to the inside? Had the neoprene doubled up on my L layout and it just didn't look right at all.
Thanks,
Danny C
dc6287
Re: Suggestions?
Postby TsgtRet » Wed Apr 06, 2016 11:16 am
Use foamboard and carry your "infield" right up to the track edge. See this posting for details (scale shouldn't matter): Reviews/ReviewArchives/CZAR/Gneissring%20sixth%20final.pdf
Re: Suggestions?
Postby dc6287 » Wed Apr 06, 2016 12:34 pm
Ha! Read that right after I posted, lots of great info.
I did try doubling it up, works great as you can see by the 2 that flowed it so fast they spun
dc6287
Re: Suggestions?
Postby BARC 1 » Thu Apr 07, 2016 6:11 pm
I would paint the track and borders.
Re: Suggestions?
Postby dc6287 » Fri Apr 08, 2016 8:42 am
dc6287
Re: Suggestions?
Postby dc6287 » Fri Apr 08, 2016 1:15 pm
Tore up, redisigned, and laid in foam...already looks smoother
dc6287
Re: Suggestions?
Postby MichiganCur » Sat Apr 09, 2016 6:58 am
I get a 404 error on that link. The update on your track looks great. :-D
Sent from my SM-G900V using Tapatalk
MichiganCur
Re: Suggestions?
Postby TsgtRet » Sat Apr 09, 2016 8:24 am
Looks great! A little paint and scenery and you're good to go. Is that an alien UFO on the infield? :lol:
Re: Suggestions?
Postby TuscoTodd » Sat Apr 09, 2016 9:45 am
Re: Suggestions?
Postby MikeySlotCars » Sat Apr 09, 2016 2:58 pm
A few tips if you don't mind , since I worked with Foamboard before on my last layout & learned from a few mistakes
First painting...
I would highly recommend spray paint or airbrush on it in very light coats & let it dry between coats otherwise the Foamboard surface (paper) will get to wet & will peel off
If you want to paint brush or paint roll the Foamboard you will have to remove the surface paper first by soaking the foamboard in water until the paper start to comes off on it own then you only be left with the foamboard that you can then paint with a roll or brush...
You always can paint roll over the foamboard without removing the surface paper if you go in very light coats & if the foarboard is securely "glue" on the table surface otherwise it will start to be uneven & will lift up here & there when it dries...
You can use hot glue to glue the foamboard on the table but I would suggest using insulating film tape it will hold really well & will be make foamboard easier to removed if you ever change your layout...
Last thing I learned after some testing is that even the 5mm foamboard which is 1mm lower then the Carrera Go track change nothing for cars to drift/slide through the curves so I went through lots of effort to make the foamboard flush to the same thickness of Carrera track which was not necessary as the 1mm difference won't affect the cars drifting through the curves
Mikey
MikeySlotCars
Re: Suggestions?
Postby dc6287 » Sun Apr 10, 2016 10:28 am
Agreed Mickey, I used the tape, and the 1mm drop is fine for 1/43 and 1/32 to slide out. Between the wife being an art teacher and me running my own painting company we will devise some paint technique to work... Meanwhile the testing continues...
dc6287
Re: Suggestions?
Postby BARC 1 » Mon Apr 11, 2016 7:39 am
Nice progress. Love the picture of your tester. My 16 month old Granddaughter has held the Parma controller in one hand and worked the trigger with the other. I give her a full Mag go car and she actually has grasped the concept of what the trigger does. Instead of just gunning it she gets the car around the track with some trigger action along the way. She loves the slot car track, and I am blessed to see her daily. She always wants to be shown the track and cars.
