Ferrari 158 Diecast conversion
Postby BARC 1 » Sat Feb 20, 2016 3:43 pm
Well I finally found the car that I thought would make a nice diecast conversion. All in the car weighs in less then 40 grams, and should not be a strain on the small M class motor. Not a scratch build so I thought I would throw it here.
It runs very well and the style of car means the diecast is not a hinderence and in fact the weight probably helps this small car. I have yet to flip it going into a corner and it is in fact very stable. I will be on the hunt for more of these older F1 cars now that this has turned out so well.
I had to mill some of the frame for the gear and make some clearance for the " engine".
Re: Ferrari 158 Diecast conversion
Postby ourwayband » Sat Feb 20, 2016 4:44 pm
Great looking build!
Postby cyclone60 » Sat Feb 20, 2016 6:10 pm
Like it very very much !!!! :music-rockout: :music-rockout: :music-rockout:
cyclone60
Postby MichiganCur » Sat Feb 20, 2016 8:43 pm
What type of voltage are you pushing on those little m20s?
Sent from my SM-G900V using Tapatalk
MichiganCur
Postby BARC 1 » Sat Feb 20, 2016 11:53 pm
I am running a stock Carrera wall wart. I think it puts out about 14 Volts, but the car only sees that voltage for a brief time down the front straight. They get quite hot after a time so I am sure they will fail at some point.
With no magnets there is not a lot of strain put on them and they seem to be doing OK. I have used them in the last 3 chassis. The Porsche 906 went real slow after an endurance run, but I let it cool down and it is fine again.
So some caution and a failure should be expected when running these.
Postby pfuetze » Sun Feb 21, 2016 2:39 pm
awesome conversion!
get some H0 BSRT gears, they are a little smaller
great work!
Postby MichiganCur » Sun Feb 21, 2016 10:17 pm
Nice. I was using some at 9v and they would get quite hot after a bit. Never lost one while I was on the project but was wondering if they would pop any higher than that.
MichiganCur
