Need Cheap replacement motor for 1/43 scale Carrera Go cars?
Postby dave1566 » Tue Nov 24, 2015 9:11 am
I am in Need of Cheap replacement motor for 1/43 scale Carrera Go cars?
If anyone knows of where I can buy over 100 of these style motors I would greatly appreciate it.
They have a 1mm shaft thickness.
They are 3/4" long without pinion and a little bigger then an 1.375" long with pinion.
They are 1/2" wide and 3/8" high.
I have the plastic pinions for them.
if anyone knows of a replacement please let me know.
Thanks, Dave
dave1566
Re: Need Cheap replacement motor for 1/43 scale Carrera Go c
Postby Cjent » Tue Nov 24, 2015 11:54 am
Welcome, Dave. I hope someone here can help I'm out too.
Cjent
Postby pfuetze » Tue Nov 24, 2015 12:26 pm
I do not know a cheap direct replacement, sorry.
Only motor of the same size is the "tuning motor" from Go!Karli in germany.
Postby walker » Thu Nov 26, 2015 11:31 am
The real GO! - motors are
l 19.5 mm
w 14.7 mm
h 10.8 mm
Their shaft diameter is 1.5 mm like all FF-030 motors.
So your search criteria may be the dimensions above, together with a voltage between 7 and 10 volts and ca. 13000 rpm, or the designation "FF-030" plus the required voltage and rpm.
" Tuningmotors " is only a name. They are ony useful with strong traction magnets because they simply have another wind that increases the rpm. The braking force stays the same resp. gets weaker, the acceleration is weaker because these motors have the same poor ceramic magnets and metal brush strips - despite their name.
Roland
First and foremost you should know what you need the motors for.
walker
